Results 1 to 2 of 2
Reload Thread: Need help constructing a box
    sjedwards84's Avatar
    sjedwards84 is offline Senior VIP Member
    Dec 2006
    Wichita, Kansas
    33
    197
    It needs to be a ported 6 cu ft box for two 12" Kicker l5s
    these subs are 600watts rms each and i will powering them with with a HiFonics BXI 1200 watt amp.
    right now they are in an 8cu ft box tuned to 32hz powered by 1 Kicker ZX750.1
    so they are only getting about half there power.
    i was told that if i was to putt 600 watts to each sub like kicker says they require in the same box i have when i hit the real low frequencies it will fry the subs
    so i'm wanting to do 600 watts to each sub in a 6 cu ft box since kicker requres 1.5cu ft - 3cu ft per sub
    there was a link to a box calculator on here once but i cant find it anymore
    can someone give me dimensions
    box is going in a yukon so size really doesnt matter
    ____________________________________________
    2004 Yukon
    Alpine CDA-9885 HU
    Two 12" Kicker L5s
    Kicker Zx750.1 amp
    Stock Speakers with Factory Bose Amp
    4ga Kicker Wiring
    Jeepjones85's Avatar
    Jeepjones85 is offline Gold Power
    Oct 2008
    South-East AR
    928
    Re: Need help constructing a box
    Well here is great web sight for all that kinda stuff from wiring subs to boxes or anything
    this box calculator figures the out side measurements and then you put how thick mdf you
    are using but you have to convert everything to decimals like 1/2=.5 or 3/4=.75 anyway
    i hope this helps this is the sight I use all the time.
    http://www.the12volt.com/caraudio/boxcalcs.asp
