Results 1 to 5 of 5
Reload Thread: Swtchable Ports
    Nov 2002
    Vancouver
    892
    Swtchable Ports
    Can anyone tell me how to build one of these things?
    How do you keep it sealed tighly if it can remove?
    Thanks
    **Resonant Engineering, Adire, Pioneer, Focal, Second Skin, Sony**
    F150Matt's Avatar
    F150Matt is offline Senior VIP Member
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    Quote Originally Posted by Biohazard
    Thanks
    Build the box with the bigger SPL port so that it will be a permanent part of the box. After doing so, build another port that will screw down over the big SPL port. Use WinISD to help with tuning, remember your net volume will likely change a good bit with the daily port in, so compensate for that in your tuning. Good luck.
    Matt Sibley
    Dad, Electrical Engineer, MBA
    Used to do these:
    Team S.P.E.A.D. Captain
    Team Kicker
    Team Maxxsonics
    USACi Pro Stock 5001+ World Record Holder
    F150Matt's Avatar
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    Just thought about that a lil more, you might want to make the SPL port removable too, usually if your serious about it you'll retune at least a couple times until u get it just right. So basically build the box and then make some different ports, there are many ways to do it, just depends what you want to do.
    Matt Sibley
    Used to do these:
    Team Kicker
    Team Maxxsonics
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    I make my port completely removable. Slid one out and the other one in. Personally I don't think it needs to be sealed to the box. If you think about it, the air is going to take the easiest way out of the box, through the port. Not much, if any, will escape from between the box and the port.
    -just me theory, I could be wrong, it happened once before.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    spyd3r's Avatar
    spyd3r is offline drunken polak
    Mar 2003
    NY
    276
    I can't agree with having leaky ports....
    Try drilling a hole in a ported box.... and then push your sub a bit....there's not such a big performance drop...but the air leak will be annoying as h3lLL.
    Just find out your resonant frequency of the car if you plan on competing for your spl por and make that the permamnet portt...then tune a removable port to mid low 30's for your daily driving.
    Keeping the enclosure air tight is a must.... Don't take too much effort. The whole point of portin to a desired frequency is for the sub to not reproduce any frequncies lower than the tuning. If you have a leak....then your tunning will most likely rise.
    Think of air as a dense volume of gas. It doesn't just take the least restrictive path.. it gets in everywhere.
    Sound quality enthusiast with a Silver GTI VR6
    *Eclipse ecp 416 *Diamond Audio D7054 *D7152 *Diamond Audio Hex 10" *phazeaudio/studio_drivers/alumapro dual mid 6.5's alc compoenents
