Results 1 to 9 of 9
Reload Thread: Fibreglass your doors
    Nov 2002
    Vancouver
    892
    Ok if you are making a so called "kickpod" type dealy for your doors, do you make it enclosed? or do u just build what you see and have the speakers in no sort of box?
    Do you get what i mean?
    like so...are each speaker compartments sepereate??
    **Resonant Engineering, Adire, Pioneer, Focal, Second Skin, Sony**
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    you mean free-air, or seal it off? I've had the notion that component drivers were designed with free-air in mind. It's only when you install specific mid-bass drivers that requires a baffle for better performance that such a box (and should be quite small) is called for.
    I read from MBtech that all MB quart's components and coaxials were designed to work in free-air installs.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    Biohazard's Avatar
    Biohazard is offline I AM
    Nov 2002
    Vancouver
    892
    using focals...soo i dunno...and an RE8, but i will cover the 8 in a small little like boy type thing...
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    well, all the installs I've seen with focals had no enclosure to speak of, just a pod to hold the driver in place. I dunno if you would see improvement with the unit in a sealed box.
    As for the RE8...whoa, you drive a 18-wheeler? How do you plan on getting an 8" sub like that on your kickpanel?
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    I personally sealed my focal components. It seems to have tightened up the sound. And makes the low end a little clearer to my ears. I'm using a set of the polyglass
    5 % equipment
    90 % install
    5% beer
    Biohazard's Avatar
    Nov 2002
    Vancouver
    892
    hrmmm...i see.....i have the polyglass to so then maybe i will close it off..
    as for the RE8's i was gunna try to build it on the door like the picture but i will build the pod first and see if it takes up too much room......
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    how would u seal it off? just make n enclosure of any size just as long as it's air tight?
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    I used lspcad and help from Mr. Matt Borgardt over at http://www.carsound.com to determine the enclosure size. To seal it off I just simply glassed the back closed once it was the kick panel was mounted. You can do it before you mount it. But I wanted to see what difference it made sound wise.
    5 % equipment
    90 % install
    5% beer
  9. #9
    hihoslva's Avatar
    hihoslva is offline Member
    May 2003
    Long Island, NY
    83
    If you run a 3-way component set sealed, it is important to separate the midbass from the midrange.
    Just like it's not a good idea to run a 12" and 8" sub sharing sealed arispace, the same is tru for component speakers.
    For 2-way comps and non-sealed pods, there is no need to separate the space for each driver. And since tweeters don't reallt have any airspace or air-displacement issues, they can share airspace with just about anything.
    Only matters for a 3-way component set run sealed.
    ~HH
    2002 Sunlight Silver Metallic Mazda Protege5
    Kenwood~Lanzar~Infinity~Peerless
