Results 1 to 8 of 8
Reload Thread: Box Help
    BDIDDY's Avatar
    BDIDDY is offline Sittin' Slick
    Mar 2003
    Tennessee
    30
    2,575
    Box Help
    I was wanting to build another box because the 5.5 cuft. tuned to 50 hz is not cutting it sq wise. Just wondering you alls recommendations. I was thinking 4 or 3.5 but 3.5 would be a little more to figure out tuned to about 33 hz. I want your eyes to water and this thing to go extremely low. I dont know about the port size as I mean the area but any recommendations are welcomed.
    Thanks.
    "Just have to remember to take everything in stride, and don't put off till tomorrow what you can do today because there might not be a tomorrow. " <---- RAMOS
    Profliepower is the funniest guy ever...
    BDIDDY's Avatar
    Mar 2003
    Tennessee
    30
    2,575
    Well I did it myself after looking at some posts on here and was wondering if this was right. It will be 4 and after looking at this other post the guy said to add the port and sub displacement to the net volume so I got 4.8. I think that is a little big but then I tuned it to 33 hz with the port being 13 high x 3 wide x 25.35 deep. I was wondering if the port face was to big to small or what? Look for how I want the sub to hit up top.
    Thanks.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    If you went 4cu' at 33Hz, you will get a huge spike of 7.8db at 35Hz.
    If you want good sq and a strong low end, I would make a box 3.5cu' and port it to 24Hz. This would give you a pretty flat response with a slight peak of 2.5db at 26Hz. You will have a strong low end (between 22 and 38Hz) The brahma can do the low notes, that should sound pretty cool.
    Oh yah, a port 3"w, 6"h, and 20.5"l should get you there.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    BDIDDY's Avatar
    Mar 2003
    Tennessee
    30
    2,575
    Is there any way that you can chage that port to 13 high x whatever else? And what does the spike have to do with anything?
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    You could go with 13"h x 2"w x 28.5"l
    For good sq you are looking to get a "flat" response. In short, this means that all freq's. will be reproduced at the same volume. For an ideal spl box, you would be looking for a large peak at the freq. you are trying to achieve. But by doing this the box will only correctly reproduce the desired freq. Personally, what I like to do, is make a box that has a slight peak at the lower end, because I like low end bass, and then keep it flat from there on up to maintain my sq.
    2006 Jeep Liberty
    *Vb = vol. in cu"
    bumpin_blazer's Avatar
    bumpin_blazer is offline Only the Strong Survive
    Mar 2002
    Austin,TX
    36
    8,044
    my question is why make the box so big?? why not go for a lil bit smaller box and tune it low like trixter said?? i agree that tuning it to 33hz is good but i'd go lower in the upper 20hz range.
    adam
    2006 Bright Island Blue 6s: stock 6 disc in dash, Hertz Hi-Energy 6.5" comps, MB Quart Ref 12", eclipse 5-channel sub amp.
    Car mods: Lowered on Mazdaspeed springs with Koni Yellow shocks, Racing beat front/rear sway bars with AWR end links, LED turn signals, tail lights, front side markers, 18" ADR Cypher rims, 55w HID's in low beam and fogs, 5% tint all the way around. No go fast mods yet...tuning and Mazda6 don't go well together .
    Steve a.k.a. ss3079: So this one lady goes, "These ignorant people who drive around blasting there music, they cant hear emergency vehicles"
    So that set me off, and I said "Well then why do they let deaf people drive?"
    AOL: JmKeenen
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    Yah, the only reason I suggested to tune it so low is so you can get a samll peak in the upper 20Hz range. I normally wouldn't do this, but I know that the Brahma can do it nicely. You could also go with a smaller box and still get the freq. you are looking for by changing the port size. In fact, WinIsd reccomends a 2cu' box ported to 25Hz to get a flat response. I just increased the box size a little to get a stronger low end.
    2006 Jeep Liberty
    *Vb = vol. in cu"
    BDIDDY's Avatar
    Mar 2003
    Tennessee
    30
    2,575
    So go with the 3.5 ported right? Yeah after I thought about it, it was too big. But thanks for the help and enlightening me on peaks and stuff like that. I understand that much more.
