Results 1 to 5 of 5
Reload Thread: how thick
    pxcr440's Avatar
    pxcr440 is offline Member
    Jan 2002
    hudson, iowa
    28
    43
    how thick
    how thick does the fiberglass walls have to be to not get the nasty echo sounds that are common
    Prozac's Avatar
    Prozac is offline Junior Member
    May 2003
    Colorado Springs, CO
    40
    Out of all the research that I have done, most people say that it should be 7-8 layers thick or about 1/2". Hope this helps.
    Prozac
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    yeh, anywhere from 1/2-3/4.. 7-8 layers should be fine, if properly done.
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    It all depends on the type / kind/ weight of your mat and or cloth you are using. If braced properly it can be done using two or three layers of kyntex biaxial mat.
    5 % equipment
    90 % install
    5% beer
    hihoslva's Avatar
    hihoslva is offline Member
    May 2003
    Long Island, NY
    83
    1/2"??? From 7-8 layers?
    That's gotta be some thick matting y'all are using.
    Typically, 1/4" is fine, depending on the sub you are using. If you're planning a Brahma with 1000 watts flowing to it, 1/2-3/4" would be better.
    Thicker is always better, just not always necessary.
    I've got 7-8 layers on my enclosure, and it's about 1/4" thick. I can stand on it without breaking it or even flexing it.
    ~HH
    2002 Sunlight Silver Metallic Mazda Protege5
    Kenwood~Lanzar~Infinity~Peerless
