Results 1 to 8 of 8
Reload Thread: Double Check my measurements for AQ HDC3 18 PLEASE!!
    giants25al's Avatar
    giants25al is offline Member
    Aug 2008
    Willoughby, OH
    38
    After playing with some numbers and coming up with a design I want to double check with some of you more knowledgable members in here to make sure I dont waste my time building this box. If you have any input please share!!! Here's what I came up with. First Sub will be 18" HDC3 as stated. Amp will be AQ1200 (more power will be coming soon/ future plans for 2 18" HDC3's on 2 AQ 2200's), going in a chevy blazer S10.
    Width= 36"
    Height=20"
    depth=24"
    gives me + 8.5^3 before ports and speaker
    Ports will be (One on each side of box)
    Width= 3.5"
    Height=18.5"
    Lenght=15.5"
    total port area= 129.5in^2
    gives me 6.5ft^3 @ 38hz. before speaker displacement
    Only question I have is using the re calculator I had to put in a port width of 7". Would I be better off with just 1 7" port with the same height and length measurements above or go with my idea of cutting the port width in half and making two 3.5" ports as stated above. I know that the extra piece of MDF will cut into my dimensions a little but I can't see it making that big a difference. I'm lookin for around 6ft^3 gross @ 37-40 hz. Thanks in advance for any info/help. I really don't want to waste my time if I dont have to
    Edit: Speaker will fire up and port to the back of truck
    Anonymous's Avatar
    Anonymous is offline CarAudio.com Veteran
    Jan 2005
    Cantonment, FL
    2,179
    Re: Double Check my measurements for AQ HDC3 18 PLEASE!!
    either way will work and you will have more than enough room and it should be loud as hell with that port area and tuning.
    giants25al's Avatar
    Aug 2008
    Willoughby, OH
    38
    Aight good thats what I was hoping to hear!!! anyone else with any input or advice???
    giants25al's Avatar
    Aug 2008
    Willoughby, OH
    38
    Anybody??? I'm guessing my design is a good one. I'm sure if it was terrible I would have definitly heard some more responses
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,775
    5 Post(s)
    1264 Post(s)
    You only need 104^2 of port for 6.5cubes....
    giants25al's Avatar
    Aug 2008
    Willoughby, OH
    38
    wouldn't that change my frequency though. Also where at in my dimensions could I adjust to get the proper size and tuning, I thought I had this figured out lol. Just make the port a little shorter ??
    giants25al's Avatar
    Aug 2008
    Willoughby, OH
    38
    Also are you referring to 6.5^3 before ports and sub displacemnt or the gross displacement. I'm showing a net of 8.5 before the port and sub
    TSGP's Avatar
    TSGP is offline Banned
    Jul 2008
    Alabama
    1,652
    Quote Originally Posted by mlstrass View Post
    he doesn't have much more then that...
    Its fine....12-15 sq inches is just a rule of thumb.....
    Box seems to ok, just make sure you put the baffle on the outside of the enclosure and make sure you double layer everything
