Results 1 to 3 of 3
Reload Thread: Plexi glass Help
    mercdes booming's Avatar
    mercdes booming is offline Junior Member
    Apr 2003
    ga
    31
    Plexi glass Help
    i was wondering how to get plexi glass to attach to wood. like im cutting a jl audio sysmbol out of plexi glass and was wondering on how to get it to fit into the wood and make it stay there. could u help me out.
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    well my first guess would be screws.. you can use an apoxy but if ur plexi is clear and u dont apply it just right, it could turn out looking crappy. is it colored plexi, or no?
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    if it doesn't need to be flush, just screw it on like wood....if you want to make it flush i would recomend making it fit very snug and then usuing flat steel (aluminum would work too) and making molding that goes on the inside and outside, then put it in place with the molding a LOTS of cauke in between, screw it all down and let it dry (hint: use a lot of screws, unlike the rest of the box, the screws are doing most of the holding in there)....though I have no tried it, if you were carefull, you could use liquide nails instead of silicon which would make it much stronger, but you would have to keep that out of sight.
    I'm back to stock in my new car.....
