Results 1 to 7 of 7
Reload Thread: How to build a box
    joesf's Avatar
    joesf is offline Member
    Nov 2002
    Alabama
    30
    127
    Icon32 How to build a box
    I was wondering if there is any special technique in building a ported box or it is jsut a matter of screwing the MDF together sealing the ends and I was also woundering what type of sealent to use to seal the box and where to use it on the inside or the out side?
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    well ported can sometimes be called a little harder than sealed, and it is, but not that hard at all. Every box needs to be sealed completly unless its ported, but even then every corner and edge needs to be sealed. In my expriences with building boxs, if you use anough liquid nails on all sides when ur screwing the peices together it doesnt even need sealent. If there is a part on tho box where i see some liquid nails hasnt splurged out when i screw it together, ill either throw some wood glue in there then liquid nails over it, or just spread the liquid nails on it. Any sealent will work though, for the most part... Sealing it in the inside will usually be easier, because u have concave angles and such, but i usually make sure its sealed from inside and out.
    Only "tricks" for a ported box is calculate all ur measurements and think it through before u cut.. But like ive said before, when building simple box's, u can really only make a $10 mistake, cause thats how much the wood costs.
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    n0ftInc's Avatar
    n0ftInc is offline Spoilers Up. Kula Style.
    May 2003
    A Foolish Pleasure In MI..
    711
    Question time..
    In a ported box.. What would be the differences between the two..?
    **Tuning High / Tuning Low
    **Long Port / Short Port
    **Circular Ports / Slotted Ports
    **Port Area.. another thing.. what is Port Noise..?
    Sorry.. Newbie In Training..
    '93 Corrado SLC
    Alpine .. SI .. Adire .. Orion .. Optima .. KnuKonceptz
    mgaidica's Avatar
    Jan 2003
    Northville, MI
    3,065
    Originally posted by n0ftInc
    Question time..
    1. Tuning high will give u a better extension of higher frequency's, while low will have a better extension of lower frequencies..
    2. Longer will tune lower, shorter will make it tunned higher.. but u find out port length by the sub and box volume, not just guessing.
    3. doesnt matter, port volume is more important, although there isnt a set number.. the larger, the better in most case's.
    4. Port noise is air turbulance, when the sub push's and pulls it moves air, of course, and when u have sharp edges or the air hitting something it will make a noise.. (aerodynamics)
    AIM- Mgaidica
    n0ftInc's Avatar
    May 2003
    711
    Is it an extreamly noticable thing..?
    '93 Corrado SLC
    ShaunMac's Avatar
    ShaunMac is offline Thank You Come Again!
    Feb 2003
    GEORGIA
    585
    It can be.
    Pioneer 8600 - Profile Amp-Infinity Speakers - L7 Subwoofer
    n0ftInc's Avatar
    May 2003
    711
    hmm.. thanks ya'll.. I'll be sure to get a shitload of help when makin my first..
    '93 Corrado SLC
