Results 1 to 4 of 4
Reload Thread: Glass Window
    Black Truck 10's Avatar
    Black Truck 10 is offline Senior VIP Member
    Jun 2008
    Houston, Tx
    384
    2 Post(s)
    Glass Window
    I am planning on putting a glass window on the inside of my sub box. I am curious as if it will sound different by using Lexan or Plexiglass rather than MDF or birch. I only want it for the front of the box. I would put it in a frame and everything.
    The glass would be about 10 inches tall and 48 inches wide.
    If I used Lexan I can get it in 1/2 inch
    If I used Plexiglass I can get it in 3/4 inch
    Which should I use, I want the most out of my new SI Mags?
    SOLD TO: Working on it. . .
    BOUGHT FROM: Team H&K (7-17-08), lyttleviet (8-1-08)
    Aug 2005
    pa
    34
    2,191
    1 Post(s)
    Re: Glass Window
    3/4 inch plexi. 48 inches is pretty huge def get the thickest you can afford to buy
    Hyundai Tiburon
    Front: CDT EF-61CFi/25
    Rear: none
    Subwoofer: 10" Sundown Nightshade
    Box: Custom Box 1.6 cubes 36hz
    Speaker amp: Sundown 100.2
    Sub amp: Sundown 1500D
    Battery: Kinetik hc800
    TL: ??? will get it metered when its all finished
    Team: Sundown
    Refs:
    JBLCAMRY, Bjfish11, Sundownz, Slammed, Grinder1989, lilmaniac2, exige, blackbonnie
    Jun 2008
    Houston, Tx
    384
    2 Post(s)
    Re: Glass Window
    Ya it is big, but I was thinking since I found out its better to have 2 seperate chambers for the subs that I would just cut it in half and then I would only have 2 24'' pieces.
    To add another question if im running two si mags sealed do yall agree to have 2 seperate chambers or 1 big one? Would 3/4 plexi still flex at 24 inches wide 10 inches tall?
    Aug 2005
    pa
    34
    2,191
    1 Post(s)
    Re: Glass Window
    My box is 24x12. I chose 3/4 inch plexi.
    Seperate chambers would probably be better just incase one sub doesn't really take away from the other.
    Hyundai Tiburon
    Rear: none
    Team: Sundown
    Refs:
