Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: rec. a box size for my brahma...
    d audio 450's Avatar
    d audio 450 is offline Registered User
    Nov 2002
    Pa Philly area
    28
    752
    anyone have any recommendations on what size my box should be for a 15" brahma? im planning on going sealed, and i want real clean tight-hard-hittin bass. i really dont want to go ported cuz to be honest i dont think id be able to pull of constructing a box thats tuned to a specific freq. Adire recs like 2.5cuft, and in general anywhere from 1.3-3.5 i think it said.
    well, any suggestions or advice greatly appreciated
    thanks
    -pat
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    ide say anything they recomend is fine.. dont be intimidated by ported box's, way to many people are and theres no reason to be.. but u said tight clean, so maybe sealed is best. I must say though, from what i hear that thing will stay tight and clean in a good ported box..
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Using WinISD....
    2.5cu' = 42Hz
    3cu' = 40Hz
    3.5cu' = 38Hz
    I would go with the 3.5 because of the lower freq. response.
    Although I plan on putting mine in a 6cu' ported box tuned to 26Hz
    2006 Jeep Liberty
    Adire Audio, Cadence, Clarion, MB Quart
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    Nov 2002
    Pa Philly area
    28
    752
    thanks a lot guys- trixter- how would i go about bring the tuning freq down? would it be hard to get it down to like 25Hz?
    thanks again
    -pat
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    The lowest freq. you can go with a sealed box is 26Hz...and that's in an 60cu' box!!
    2006 Jeep Liberty
    *Vb = vol. in cu"
    Nov 2002
    Pa Philly area
    28
    752
    wait...holy carp i thought u were talkin about ported boxes...i didnt even know you could tune sealed boxes...
    what about a 5cuft box...whats that?
    -pat
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    5cu' - 35Hz
    The only tuning you have for a sealed box is it's size...the bigger the box the lower the freq. (that's why people cheat and use poly-fil.)
    2006 Jeep Liberty
    *Vb = vol. in cu"
    slipknot87420's Avatar
    slipknot87420 is offline ^^^^^^420^^^^^^
    Jul 2002
    huntsville alabama
    25
    1,935
    24
    i thought after you went so big that it was like IB because i dont think a sub in a sealed 10cube box would work to well
    93 blazer
    Panasonic>>>>Orion>>>>Kicker>>>>Pioneer
  9. #9
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Depends on the sub. A 15" Brahma in a 10cu' box has a flat response tuned to 30Hz...looks like it would sound good. But if I was looking for this effect, I would just port it in a reasonable sized box.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  10. #10
    Nov 2002
    Pa Philly area
    28
    752
    so what if a i made a 5 cuft box and loaded it with poly fill? any idea?
    thanks again
    -pat
  11. #11
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    You are only supposed to use something like 1/2lb of poly per cu'. At that rate, you may make it seem somewhere closer to a 6cu' box and get it down around 33Hz. If you are concerned about getting a lower freq., why don't you go ported? A 5cu' ported box tuned to 24-26Hz would sound awsome. If your concerned about it being difficult, just go with a round port. If you can cut a hole, you can make a round port.
    (I'm going with a round one so I can change it at comps.)
    2006 Jeep Liberty
    *Vb = vol. in cu"
  12. #12
    Nov 2002
    Pa Philly area
    28
    752
    ok. but does where the port is placed affect the tune freq?
    could i port a box like this? with plexi galss? (blue)
    thanks
    -pat
    Attached Thumbnails Attached Thumbnails rec. a box size for my brahma...-port-.gif
  13. #13
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    You can put the port anywhere you want w/o the tuning being effected. With something like that, I would put it in the top. Just make sure that you leave as much room between the end of the port and the opposite side of the box. What I mean is, let's say your using a 4" diameter port. When it goes into the box, it needs to be at least 4" away from the opposite side of the box. (If you don't understand, let me know and I'll draw up a pic.) You say your concerned about it being hard to make a box w/ a port, but you making a plexi window? How is this sealed and kept from flexing? If your doing this, a port should be a piece of cake.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  14. #14
    Nov 2002
    Pa Philly area
    28
    752
    as for the plexi glass- i drew it in that pic way to big, with the brahma and a 1200.1 it would blast it apart unless i used reeeal thick pglass. , i want to have a little window, maybe even as small as 6x6 cuz i wanna throw a neon inside (i just like the effect) and have the sub glow blue or whatever color. I just got home 20mins ago from home depot and i bought 2 4x4 sheets of mdf, 3/4" , tee nuts, and bolts and screws... i really appreciaste the help and all- i just have one last question:
    if i put it in a big box, and say its sealed tuned to 33hz or whatever, does this mean that its freq-response graph will be spiked at 33? is this spike smaller than if i ported it?
    thanks again
    -pat
  15. #15
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Actually, the 33Hz is at -3.5db in a 6cu' box (or a 5cu' box w/ poly-fil) It hits 0 db at 84Hz and flat lines from there. There is no "spike". I think the only way to achieve that is to go ported.
    With my box, 6cu' ported to 26Hz, I get a +3db spike from 30-34Hz. I like this set up because it will produce a strong low end.
    2006 Jeep Liberty
    *Vb = vol. in cu"
