Results 1 to 15 of 15
Reload Thread: Ported Box questions?
    dpu2014's Avatar
    dpu2014 is offline Senior VIP Member
    Apr 2008
    Indianapolis
    236
    Ok I am trying to build a ported box for a friend but how do i know how big of ports to use? how long? etc. And before u tell me to use SEARCH, i already have.
    hatemonger's Avatar
    hatemonger is offline funded*by*soros
    Mar 2006
    Denver, Co
    37
    9,025
    Re: Ported Box questions?
    search "port calculator"
    2003 chevy s-10 ext. cab
    hu: jvc kd-avx1
    precision power 356cs components
    front amp: infinity 475a
    sub: diamond audio d6 10d4
    enclosure: 1.1 cubes ported tuned @ 31hz
    sub amp: JL G1700
    a_steezy's Avatar
    a_steezy is offline Banned
    Apr 2008
    Renooo
    339
    google 're audio'
    then under the first thing it'll say encloser calculator or something
    it's easy to find and works good
    dumpin907's Avatar
    dumpin907 is offline bout money
    Dec 2007
    AK
    1,258
    first tell us the sub, the amount of power, the vehicle,and what music he listens too
    HELP ME FIND A NICE AMP ~3500@1 and ~2000@2 PLEASE. (RD,IA,AQ,RE,US,AB,DD,SUNDOWN,SOUNDSTREAM,KICKER ect.)
    REFERENCES = MBOTE,DONPISTO,MXMAN38,HOXIE08,INFRAJA,RICOSHAY SHIIPSEKI,BALLINBYNATURE,LAMA04,TC2k15x2 AND 100% FEEDBACK ON EBAY WITH OVER 20 TRANSACTIONS. USER NAME= RAD4RD07
    tooloud4tv's Avatar
    tooloud4tv is offline CarAudio.com Elite
    Jun 2007
    Georgia
    1,566
    got****e~ what size subs,box u are using i will be able to help you further!
    Had some problems but working them out donpisto is an grate guy for working with me still!
    dpu2014's Avatar
    Apr 2008
    Indianapolis
    236
    ok thanks i just found it. also, what is the difference between the boxes that just have the tube ports vs the boxs that have the big slots.
    tooloud4tv's Avatar
    Jun 2007
    Georgia
    1,566
    Quote Originally Posted by dumpin907 View Post
    x2
    hatemonger's Avatar
    Mar 2006
    Denver, Co
    37
    9,025
    Quote Originally Posted by eastfootball View Post
    i think you should do some reading before firing up the tools
    hu: jvc kd-avx1
    sub amp: JL G1700
  9. #9
    a_steezy's Avatar
    Apr 2008
    Renooo
    339
    Quote Originally Posted by kcdc30 View Post
    haha x2
  10. #10
    dpu2014's Avatar
    Apr 2008
    Indianapolis
    236
    two small 10inch kenwoods. 150 watt rms.
  11. #11
    dpu2014's Avatar
    Apr 2008
    Indianapolis
    236
    and he listents to all kinds of music. So i was thinkin around 35hz. The problem is I dont know how to tune a box to a certain hz. I just built a sealed enclosure for my 15 fi Q so now Im tryin to learn the world of ported enclosures as well.
  12. #12
    dumpin907's Avatar
    Dec 2007
    AK
    1,258
    go to reaudio.com use the box calculator. you can enter all the dims and adjust port size to get the tuning you want
  13. #13
    dpu2014's Avatar
    Apr 2008
    Indianapolis
    236
    that is for L ported boxes. This wont be L ported.
  14. #14
    skmfkr's Avatar
    skmfkr is offline CarAudio.com Veteran
    Jan 2005
    Savannah, GA
    26
    6,350
    '08 Ford Escape XLT
    2 12" DC XL's + 2 RD D9s
    Selenium and Crescendo on AQ4X90
  15. #15
    dtbrown's Avatar
    dtbrown is offline CarAudio.com Elite
    Aug 2006
    morton grove, il
    35
    919
    An areoport difference http://www.partsexpress.com/pe/showd...number=268-354
    to a standard slot port for music is mostly a build,spl,tuning difference.
    Areoports are very efficient and loud due to the flared ends that you see in the picture. Areoports are very easy to tune and you can make the box smaller due to you don't need the extra space for the slot port. Great for cars with limited space for a box
    Slot ports work pretty well but typically require a bigger box and are pretty much untunable unless you make it so that you can take the slot port out and either make it shorter or longer. So with a slot port box you'll need to gather a lot of info so you do it right the first time.
    Me personally have been using areoports mostly due to the ease of use and they are loud as hell if set up right. Cost wise you'll spend more with areoports due to the initial investment on the ports. But if you want a simple ported box that sounds good with ease of build and won't dig into your wallet go slot port. Just do your research for the specs you'll need for the port size, length and box size.
    Good luck.
    So far loudest Toyota Yaris with two 10's.
    2008
    154.1 certified (new rules) on termlab Db Drag Street A. Equipment: DD 9510's and one Stetsom 7k2d on a small Stinger 1750
    2007
    155.3 on termlab Db Drag Street A 2007 WF 4th place. Equipment: DD 9510's and two Stetsom 7kd's with a Cacuts Sounds CS9000 Battery.
