Ok guys as yall already know im preparing to make my new fiberglass box for 4 audiobahn 10"s. I've done fiberglassing before but i have never had plexiglass before. I finished with the planning got all the materials but one thing. I need some plexiglass or something perfectly clear, do yall know where i could get it?? And how exactly would i embed it into the fiberglass. Would i just build a MDF frame and fiberglass the frame in place or would there be anything else that i would need to do. What thickness should i use for the plexiglass. Im running 4 audiobahns at about 1200w each so im guessing it would need to be kinda thick. And how do i cut plexiglass or can i even do that? oh and about how much does it cost?? Any help would be appreciated. Here is the design of what it should look like after completion. I looked at alll the links but could find anything that could help me out on this techniques.
Register To Reply
like lexan and more. i'd suggest getting the thickest stuff you can find. actually...i would suggest not using glass with that much power....but if you insist....try and get something at least 1" thick. decide on the exact dimensions and have them cut it there. it might end up costing a couple hundred dollars....its really not cheap stuff.
It is extremely expensive the thicker you get. You can get an idea of the price by checking out
Bookmarks
