Build Help
Ok so Me and my second dad are building a box. 22.5W x 19D x 14.5H. Well we screwed in some sides. On one end on a peice of wood, it split just a little bit. Not much and that is the only one. Figured to just ignore it, right? Well instead of wood glue, could we use some caulk that sticks just as well? He swears its tougher than wood glue. Or what about Gorilla Glue? We plan to finish up tomorrow or friday and we are goin to use caulk to seal up all edges. Sound good? Aeroport box by the way.
Re: Build Help
Mix some glue with sawdust to fill in the crack...
Re: Build Help
Vehicle: 1999 Nissan Sentra GXE 4-Dr [ Lambo Doors ]
Head Unit: Alpine CDA-124SXM
Front Stage: Kicker DS6.5s w/ (4) Power Acoustik NB.4s - Rear Stage: (4) JVC 5-Way 6x9s
Sub Stage: 18" FI Audio Q - Custom Ported Enclosure: 6.41 cuft Tuned @ 29Hz
Sub Amp: (1) Kicker KX2500.1D - Highs Amp: AutoTek AT-1200.4
Processors: Clarion EQ-746 & Clarion MCD-360
Wiring: Install Bay 1/0 Gauge ( Including Big 3 Upgrade )
Batteries: EverStart Maxx's ( 750 CCA ) In Front & Back DJ's Installation
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
