Is MDF the only wood recommended or are their other woods that would work just as good?
"I am going to get a stereo so loud it can blow womens close off" Seth Green
Mmmmm..... Bass.
1f U C4N R34D TH15 U R34LLY N33D T0 G37 L41D
3/4" or larger MDF is standard box building material.
I've tried hard woods (Cherry, maple, birch, mahogany, etc) and it worked just as well - the overall thickness I used was about 1". More expensive, but worth it if you're going for that natural wood look.
- Steve
Moderator
2007 Chrysler 300C
2005 Chevrolet Silverado 2500HD Crew Cab
Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
2006 Kawasaki Ninja ZX14
Originally Posted by DJGTSR
There are others that work as good (or better), but you usually pay more. Marine grade plywood I've found to be among the best. But at 2-3x the cost of MDF, it aint that great![]()
How 'bout 3/4" partical board??
Mmmmm..... Bass.
u can use particle board but it chips very easy
FREE Terrelll"peanut" Grayer!!!!!!!!!!!!!!!!!!!!!!!!!!
you know, smokeoff, if you're giving 3 cents each time you post (314 times), you've given up $9.42...
I'm going to get some MDF 3/4" soon, how much is it?
- pe@ce
Audio Setup:
Car: Late Model '99 Jetta
Head Unit: Pioneer DEH-P680MP
Subs: (2) eD 13Ov.2 D4
Amp: AQ 1200D
Wiring: KnuKonceptz 4 Gauge
Music: Google Play Music
Maybe I should cut back to just giving my 2 cents.Originally posted by jer_stud56
- pe@ceGood luck finding some MDF. Around here the only 2 places that carry it are Home Depot and Menards. And both of em have it on back order or something.
Mmmmm..... Bass.
If sealed with fiberglass resin, it aint so bad. But as someone else mentioned, the chips will peel off. I prefer MDF. It is almost identical in price at the HD here.Originally posted by smokeoff
Bookmarks
