Results 1 to 3 of 3
Reload Thread: millionth polyfil ques.
    Sep 2007
    pa
    101
    I got a SS T-5 from pipo in the classified sec.
    I'm gonna use it in a sealed box. The specs call for 20-50% semi-dense fill.
    What is your interpretation of "20-50% semi-dense"?
    I know the Lb to cu.ft. rule.
    Thanks for your help.
    The box building is in the capable hands of tacosys.
    Bought from Pipo, orangecounty1, blue200sx, dbman150, gearguy2001,
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    Apr 2004
    Indy
    24
    19,672
    Re: millionth polyfil ques.
    Just stuff some in until it's packed, but you can compress it into ~2-3" deep against one of the walls. That's my rule of thumb. It ends up being filled up, but loose enough to not choke the sub.
    PV Audio's Avatar
    Apr 2004
    Indy
    24
    19,672
    And no, 1 lb of polyfill to a 1 cubic foot box is almost always too much. If you're worried, just line the walls with 2" fiberglass. Seems to work better anyway.
