Results 1 to 15 of 15
Reload Thread: Used 5/8's particle board, is this good?
    Afboy143's Avatar
    Afboy143 is offline aka Bumpin Expo
    Nov 2002
    Tampa, Fl
    384
    I built a box for 2 10's in a 5/8's particle board box with no divider in the middle. Was this a good idea or should i built another with a diff wood, will this wood stand the pressure with no supports or nething? Help! Thanks
    Curtis
    1x Stereo Integrity 15" Mag
    1x Hifonics 1500.1D
    1x Hifonics 420.2
    4x Infinity Reference 6x8
    1x Pioneer 8600
    Apr 2002
    Idaho Falls
    40
    1,134
    NO!!! Not good Use at least 3/4 and I also would say use mdf instead of particle board
    '99 Ram Sport Quad cab
    Alpine 7897
    Rainbow 6.5 comp. set
    180 amp Iraqqi alt
    Optima yellow top
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    Re: Used 5/8's particle board, is this good?
    Curtis
    How much power will you be running?
    Either way, I suggest you do it right and use 3/4" MDF...if it's a sealed box, a divider will help with bracing (prevents flexing).
    Glue all of your joints with "Liquid Nails" or normal carpenters glue. Pre-drill your holes to prevent the MDF from splitting, and use screws. Run a bead of caulk/silicon around the inside seams/joints in your box to prevent any air leaks. I dont know if you are using wire terminals or not, but be sure to seal around that too (hot glue works). You can use screws to mount your subwoofers to the box, some people even use bolts. Use a piece of weather stripping around the subwoofer hole cutout...helps seal things off.
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    chelopr's Avatar
    chelopr is offline Junior Member
    Jun 2002
    San Juan, pr
    46
    No man
    3/4 is better and your sub will work better with the separator, 5/8 generates vibration an distortion.
    chelopr
    P.R.
    Afboy143's Avatar
    Nov 2002
    Tampa, Fl
    384
    Aight **** that sux, i have a reg cab s10 so i used that wood figuring it would save space. Will i notice a big diff using 3/4, like is it worth it to make another box, cuz if the box i have no is gonan distort im gonna dump it
    1x Hifonics 1500.1D
    1x Hifonics 420.2
    1x Pioneer 8600
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    You can always try it...but I bet that you will encounter some flexing.
    - Steve
    Moderator
    2007 Chrysler 300C
    Afboy143's Avatar
    Nov 2002
    Tampa, Fl
    384
    What exactly is flexing
    1x Hifonics 1500.1D
    1x Hifonics 420.2
    1x Pioneer 8600
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    34
    873
    Well flexing is basically the board moving back and forth. Basically if you take a sheet of paper and make a cube out of it, stick a straw in it and blow and ****. The paper will buckle and expand... that's what your wood might do... and you don't want that. If you are running less than 200 watts to each speaker i would worry about it too much unless you can actually see the box moving. Medium density Fiberboard is some thing too look into though because it's less porous. I know how u feel with the limited space cuz i got a standard cab s-10 too. but it's all good.
  9. #9
    more_spl's Avatar
    more_spl is offline only have 1, but it's 12"
    May 2002
    Winnipeg
    32
    1,108
    Originally posted by chelopr
    No man
    chelopr
    P.R.
    how does wood cause distortion?
    i decided not to have a signature
  10. #10
    Jun 2002
    Chicago,IL
    30
    603
    I really dont understand how you guys fit subs into your small Pick up trucks. When I look in my friends, I can't even imagine where the box would even fit. But hey, I bet you guys have your ways and know alot more about that then I do.
    98 Grand Cherokee Limited 5.2L
    H/U: Alpine
    Speakers: Polk 6.5" GXR
    Amp: Hifonics BX1500D
    Subs: 2 12" RE SE's
    Box: Custom 3.3 Cubic foot ported
    Box tuned to 35 Hz
    In The Making: 5.1 cubic foot Box
    Ported to 28 Hz with
    Pluged Port (35 Hz)
    _____________________________
  11. #11
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    That is one of the biggest challenge's...SPL from a regular cab truck - without doing any seat modifications or box in the bed/blow through combo.
    - Steve
    Moderator
    2007 Chrysler 300C
  12. #12
    Oct 2002
    Fort Meade, MD
    34
    873
    Excactly ss That's why im doing it so that people WILL FEEL THE WRATH OF THE ALMIGHTY S-10 STANDARD CAB PICKUP.
  13. #13
    Afboy143's Avatar
    Nov 2002
    Tampa, Fl
    384
    lmao at big red
    Well guys my boy and i were workin wit fiberglass today and its pretty easy accually, gotta get more pratice but we got it, we are gonna work on 2 inverted subs in the middle, and 1 sub behind each seat. Its gonna b bad ***, got everything jus need the box
    1x Hifonics 1500.1D
    1x Hifonics 420.2
    1x Pioneer 8600
  14. #14
    abcdefg's Avatar
    abcdefg is offline CarAudio.com Veteran
    Oct 2002
    Clarksville, Tn
    30
    2,330
    talk to rangerman about that, he crammed like 4 cubesout of his reg cab truck
    Pioneer Premier DEH-660
    1 12inch ED k
    2 12inch RE HC's
    Hifonics brutus 1000d
    infinity kappa 6 1/2 components
    polk 5 1/4's
    US Acoustics USX2080
    sony cd player-4sale
    jensen 4's- 4sale
    check this out guys:
    http://www.sounddomain.com/id/tumultgoboomboom
    Aim= wrde2005
    Email= [email protected]
    Aol instant message= wrde333
  15. #15
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    Lol, have you seen the box with the Brahma? I dont think you'll want to drive around like that everyday
    Though the new A box must be a little better.
    - Steve
    Moderator
    2007 Chrysler 300C
