Results 1 to 5 of 5
Reload Thread: Thoughts on enclosure for (4) Pioneer TS-W257D4
    cycloneman's Avatar
    cycloneman is offline Senior VIP Member
    Jun 2008
    Rochester,MN
    208
    Looking for some suggestions.
    I picked up the four subs, brand new from a friend for $100 total. He bought them a couple months ago, never got them installed and now needed some cash.
    Link to sub info - http://www.pioneerelectronics.com/PU...TS-W257D2%7CD4
    I know they aren't the best in the world, but for the price, they will work.
    I am looking for info on enclosure size and porting frequency. I have about 7.25 cu ft to work with (external dimensions). Pioneer recommends 1.1 cu ft ported per driver. Seems kinda small, even for a 10".
    I listen to all kinds of music. Rock, Rap, Country, etc. So, I'm not looking to have just a high output box, I also want it to sound good.
    I'll be running them for now with my old Phoenix Gold titanium 800.1 amp.
    Thanks in advance for any help.
    moorezy's Avatar
    moorezy is offline Senior VIP Member
    Aug 2007
    St. Catharines, ON, Canada
    332
    Re: Thoughts on enclosure for (4) Pioneer TS-W257D4
    I had four of the 12" version in 7 cubes net tuned 35hz and it sounded really good, i was underpowering them a little but the output was still good. I had mine in 1.75 each, and it was fine for the 12" so the 10" i don't see why the 1.1 wouldnt work, i would make a little bigger just to be on the safe side. don't forget build log. Also think of upgrading the amplifier for maximum output.
    Infinity Kappa Perfect 10 VQ (2)
    Infinity Kappa Perfect 6.1
    Infinity Kappa ONE
    Infinity Kappa FOUR
    Knu Flex 1/0
    Knu Klarity RCAs
    Pioneer AVH-4000DVD
    dB Electrical 200 amp alt
    2000 Lincoln LS V8
    cycloneman's Avatar
    Jun 2008
    Rochester,MN
    208
    Thanks......I was thinking 1.25 per, tuned to 32-35Hz. So that seems in-line with what you are thinking.
    The PG amp will do 800rms, I know it's "small" by today's standards, but it will do until I can pick up a new one. Having 6 kids (including one that just turned 16 and "had" to have a system in his car) puts a damper on the funds
    cycloneman's Avatar
    Jun 2008
    Rochester,MN
    208
    Alright.....
    Going with 5.6 cu ft after sub and port displacement. Tuned to 35Hz
    Two more questions.
    1. Will three 4" AeroPorts be sufficient?
    2. This will be going in my Saturn SW1 wagon. I would like people's opinions on sub/port placement.
    a. Subs up / Ports up
    b. Subs up / Ports back
    Thanks
    Cbass's Avatar
    Cbass is offline Livin Loud!
    Aug 2005
    31
    1,052
    I would do 5cubes, same tuning... but since you have little power for them is better that the box is a bit on the big side.
    I think that 3 4" aeros are just fine.
    And subs up port back
