Results 1 to 12 of 12
Reload Thread: Final Fiberglass Step
    I8AYellowCrayon's Avatar
    I8AYellowCrayon is offline Junior Member
    May 2003
    Baltimore, MD
    30
    Ok, I understand everything to buliding a fiberglass system now except for the very last step, paint! I want to have my system have the sleek metallic paint job shine to it. Now my only problem is now that i have 6-7 layers of fiberglass done, what do i do next for my paint? I know I have to paint it with primer at some point too but when and how many coats. Also what kind of paint do I use for painting the fiberglass and how many coats. Where can I also purchase this paint? Is there any other paint products I need to put on my fiberglass enclosure so it shines like I see it at car shows and what not? What is it and once again, how many coats? What order am I supposed to do this all in too? Thanks, I appreciate your time.
    later
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    although im not familiar with the paint part.. i know that u need it totally smooth, and some like to use bondo and SANDING a lot to make it picture perfect.. i remember someone saying the paint to use but i wouldnt wanna recomend anything bad...
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    bondo to smooth it out....then take it to an auto body shop to be painted (or a marine painting shop where they gel coat (very shiney, used on boats)).
    I'm back to stock in my new car.....
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    or you could jus use some high build poly primer (to fill in the rough spots after bondo and sanding, if u have any) then sand that smooth.......several layers of paint........final clear coat.......wet sand between coats.....apply several thick layers of clear coat and you should be good to go....
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Painting requires more sanding than anything. You have to sand your work completely baby butt smooth. Every tiny little imperfection will show otherwise. High build primer is a must. Also if you have any really rough spots that need filling. You can use the milkshake method. Mix resin and body filler until you have a mixture the consistancy of a milk shake. Then pour it over your surface. And use a plastic body filer spatula to smooth it out. Also when your using body filler. If you use a " cheese grater " type body file to knock down the ridges before the filler starts to harden completely. You will save yourself a butt load of time and sandpaper.
    If you have a compressor it's pretty easy to paint yourself. Just remember to wear a respirator and old clothes. And mask everything off you don't want painted. And no matter what method you use make sure you use light layers of paint.
    5 % equipment
    90 % install
    5% beer
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    oops..... as for the type of paint. The two and three part automotive paints work the best, and have the longest life.
    5 % equipment
    90 % install
    5% beer
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Base coat / clear urethane automotive paint. They don't come premixed in a spray can, you gotta mix and spray. Use 3 good wet coats of clear, and when it's dry sand it flat with 1200 grit. Then buff to a high gloss with a power polisher and compound. It's just like painting a car...
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    You can get them sometimes. THe auto paint store I go to will charge aerosol cans with the excess paint and sell it. It's not any cheaper really than buying it and ,mixing it yourself though.
    5 % equipment
    90 % install
    5% beer
  9. #9
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Mighty short shelf life... Catalyzed paints like Urethanes and Epoxies will cure in the can once the hardener is mixed. My local paint store will only mix enamels and laquers in rattle-cans.
    There is a nifty little spray gun made by PreVal that people without an air compressor can use.. cheap too. It uses compressed air in a can - kinda like a spray can that you can mix yourself. They do a great job from what I hear.
    dave
  10. #10
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Real short shelf life. They charge the cans for you while you wait.
    Harbor freight sells the reusable aerosol cans. I haven't really played with one yet.
    5 % equipment
    90 % install
    5% beer
  11. #11
    May 2003
    Baltimore, MD
    30
    Where to buy?
    I checked autozone and they have no autobody paint as surprising as that may seem since everyone has been telling me autozone. yeah i went two by me and neither had any. where do peop suggest i go for the paint besides autozone but still a major chain company? That or if you are from the Baltimore area, what local places can i go to?
  12. #12
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Best place for automotive paint is a professional shop that does nothing else. It's not just the materials you'll want, it's the tech help and advice. Look in your yellow pages.
    But if you insist on buying paint from someone who also sells mufflers, then go to your local NAPA... they handle Martin Seynor auto paints.
    dave
