Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: Need a box design, have $10 in paypal
    Pickler's Avatar
    Pickler is offline CarAudio.com Veteran
    Jul 2006
    Flagstaff/Las Vegas
    2,033
    So I need a box design for my 18" Fi Q in my 05 equinox. These are the dimensions I would like to use, and the width and length are max, but there is still more room in the height but then it will go above the backseat and I would rather have it not. The dimensions are 34Wx26.5Dx20H
    W=Width
    D=Depth
    H=Height
    If possible I would like to have cutsheets made as well, but if not its fine.
    Also tuning from 28-30 should be fine
    DDc 6.5" comps
    4 Sundown e8s
    refs-
    http://www.caraudio.com/forum/showthread.php?p=4720749
    vehementSPL's Avatar
    vehementSPL is offline CarAudio.com Elite
    Nov 2007
    indianapolis
    1,271
    Re: Need a box design, have $10 in paypal
    I private messaged you. check it out
    NissanKicker's Avatar
    NissanKicker is offline Honda-on-22-Nissan-on-20
    Oct 2007
    Ruston/Grambling, LA
    25
    1,420
    This should get nice, deep, & low.
    6.4cuft Tuned @ 30hz
    I PMing you now
    Vehicle: 1999 Nissan Sentra GXE 4-Dr [ Lambo Doors ]
    Head Unit: Alpine CDA-124SXM
    Front Stage: Kicker DS6.5s w/ (4) Power Acoustik NB.4s - Rear Stage: (4) JVC 5-Way 6x9s
    Sub Stage: 18" FI Audio Q - Custom Ported Enclosure: 6.41 cuft Tuned @ 29Hz
    Sub Amp: (1) Kicker KX2500.1D - Highs Amp: AutoTek AT-1200.4
    Processors: Clarion EQ-746 & Clarion MCD-360
    Wiring: Install Bay 1/0 Gauge ( Including Big 3 Upgrade )
    Batteries: EverStart Maxx's ( 750 CCA ) In Front & Back
    DJ's Installation
    Oct 2007
    25
    1,420
    Using the measurements that you gave.
    34" x 26.5" x 20" That's 10.4cuft Externally
    It's 32.5" x 25" x 18.5" - Internally ( 8.67 - 8.7cuft )
    ... After the port displacement (1.8) and an estimated .5 sub displacement. It's 6.4 cuft internally.
    The cutouts are:
    Top: 34" x 26.5" x 20"
    Bottom: 34" x 26.5" x 20"
    Front: 28" x 25" x 18.5"
    Back: 34" x 25" x 18.5"
    Side1: 25" x 18.5"
    Side2: 25" x 18.5"
    Port: 6" x 18.5" x 42"
    * Go back 19.75" D, then bend left 22.25" - Keep 6" between the port and enclosure walls *
    ( Sub and Port on front )
    DJ's Installation
    Pickler's Avatar
    Jul 2006
    Flagstaff/Las Vegas
    2,033
    Oh man i hope that 6.4 cufeet internally is enough, do you know what the tunage will be on that and would you recommend any internal bracing?
    DDc 6.5" comps
    4 Sundown e8s
    refs-
    Oct 2007
    25
    1,420
    Since the port is wrapping around, personally, I wouldn't.
    ... You could always double baffle the front.
    Make a partial faceplate: 28" x 20" - This will cover the entire front except the port.
    DJ's Installation
    Pickler's Avatar
    Jul 2006
    Flagstaff/Las Vegas
    2,033
    Well I downloaded google sketchup and tried to make a sketch, i had to adjust the dimensions because i wasn't sure exactly on if i could make a 3/4 inch think line but is this generally how it should look? and i wasnt sure on if you designed it to be sub up or sub back so i didn't add the hole in.
    DDc 6.5" comps
    4 Sundown e8s
    refs-
    Pickler's Avatar
    Jul 2006
    Flagstaff/Las Vegas
    2,033
    Well I guess I am still looking for a design
    DDc 6.5" comps
    4 Sundown e8s
    refs-
  9. #9
    Oct 2007
    25
    1,420
    Sub is in the front ( Like the port )
    DJ's Installation
  10. #10
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Quote Originally Posted by NissanKicker View Post
    The cutouts are:
    Side1: 25" x 18.5"
    Side2: 25" x 18.5"
    Displacement on a single 18" is NOT .5cubes.
    r-tard.
    nG
    http://crunktimes.com/ct/
    nG - BSEE
  11. #11
    morgans432's Avatar
    morgans432 is offline CarAudio.com Veteran
    Aug 2007
    new jersey
    2,719
    poor kid has been getting torn up lately i guess thats what happens when your a little special
    Quote Originally Posted by BumpMW View Post
    I just want 2 subs that will rattle my eyeballs and soothe my ears at the same time. The type rs did that but didn't last.
    Quote Originally Posted by mprintz View Post
    Everyone here hates on audiobahn. They are a good company, but everyone here has rich daddies and can buy whatever they want. My friend blew out his back window of his F-150 with two Audiobahn Alum12s (2000 watt max each). Go with the bahn. **** you haters.
    Quote Originally Posted by jpd2621 View Post
    24 nuts holding each rim in, what other info can i give lol
  12. #12
    kovemaster559's Avatar
    kovemaster559 is offline Official LOW BALLER!
    May 2008
    FRESNO ,CA
    6,090
    Quote Originally Posted by ngsm13 View Post
    r-tard.
    nG
    Are You always on your RAG GSM
    MYSPACEhttp://www.myspace.com/eargasm559
    MY FEEDBACKhttp://www.caraudio.com/forum/showth...96#post4669596
    PM ME IF YOU NEED CUSTOM WORK DONE FOR YOU(E.I, DOOR PODS, PANNELS, KICK PODS, anything FiberGLASS
  13. #13
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Quote Originally Posted by kovemaster559 View Post
    Nope.
    You must be thing of that whore of a mother you popped out of... now run along little boy. Heard when her gash flows it's like the bloody nile river, might wanna get you a douche canoe.
    nG
    nG - BSEE
  14. #14
    Oct 2007
    25
    1,420
    For you info... *** a$$.
    ... I know that a single 18 isn't goin' to be .5ft3.
    I did that to give him alittle more box volume... Plus the tuning of the box isn't goin' to be that low ( Since it's actually not .5 ... more like .16 - .23 )... Tuning is goin' to be ~32hz... Which I prefer to use with this particular sub ( Brand that is ). I had an 18" FI Q in my 4 runner, 7cuft. @ 33hz...
    So STFU! Before you bash someone... bash yourself.
    And I'm glad to see that you're boning YOUR mom on your AVATAR. Keepin' it in the family, eh? Good job buddy.
    DJ's Installation
  15. #15
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,737
    20
    You're slacking. Need to work on YOUR grammar, and english I guess. It's very clear that I'm humping YOUR mother... she's a big whore...
    nG
    nG - BSEE
