Results 1 to 9 of 9
Reload Thread: 4.10cuft design for a single 12" HDC3??? is that a lil big?
    slconde's Avatar
    slconde is offline Senior VIP Member
    Jan 2008
    houston, tx
    211
    ok i just want some input from u guys and before i explain, im not bashing on pete or doubting him just curious.
    well i asked for a design for my wifes 1-12" AQ HDC3. i received the plans but have not finished builig it yet but the dimensions are 36x17x15= 4.10cuft.
    so i was like **** thats huge for one 12". when i read through the forums and look @ other members signature and look at their enclosures for their 12 and they are never bigger than 3cuft. so was wondering what ur guys is take on this is. it just seems huge!!! maybe it has to do with the music i listen to.
    SeanDub's Avatar
    SeanDub is offline CarAudio.com Veteran
    May 2006
    Kansas
    24
    3,528
    19 Post(s)
    Re: 4.10cuft design for a single 12" HDC3??? is that a lil big?
    Lawl.
    It sounds to me like you took the outer dimensions and multiplied them Well imagine this: there's a port in the box, along with wood! Crazy things that take up air space. Those dimensions are gross volume. The 2-3 cubes you see written are net volume. Yours is probably right there as well. I believe I quoted another one of your posts as well. It also ended with a
    Deck: Pioneer Premier 880 w/ iPod
    In-dash: AudioControl Epic-150
    Sub: Digital Designs 9515e/f Dual 1.0
    Amp: Atomic 5000.1 @ 0.5 ohm
    Box: 3.85 @ 36 hz with 66 sq in of port
    Refs: fwb_1234, Hopes Audio, Louisiana_CRX, astrolade, nhustlar, teamquakecelica, walkychalky, negative3five, TypeRBass, jblanford (x2), massiveaudiocw, KnOkIn It 420, hoss, xtremebassjunky, trow100, MillzThaYungin, IonSQL, matrxx dude, yunvme666, vitveet, PWNED, Team H&K, jk32sho
    jnralp00's Avatar
    jnralp00 is offline well then...
    Jan 2007
    Atlanta, GA
    1,269
    definately on the large side... Try it you may be happy with it. I have had Pete design me two boxes in the past. One I was happy with, the other... not so much.
    stuckinok's Avatar
    stuckinok is offline Sick My Duck
    Jun 2006
    Rio Rancho, NM
    5,261
    it's fine
    Team High Desert Mobile Electronics ABQ, NM
    slconde's Avatar
    Jan 2008
    houston, tx
    211
    how are those aq amps?
    dillinja666's Avatar
    dillinja666 is offline CarAudio.com Elite
    Sep 2007
    a whales vagina
    514
    and it looks double baffled too.
    bought from: Sqhertz, lmllopez, 02parkave, BuckyBoy x2, Woofercooker
    "furi curi= well its whem you **** on a brindge with a **** in your *** and *** parkeing ticket **** extension cord **** lotterytict **** all night, that basicly explains it "
    jnralp00's Avatar
    Jan 2007
    Atlanta, GA
    1,269
    Great amps... Well worth what DJ sells them for.
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,602
    13 Post(s)
    Port looks pretty long, what is the box tuned to? If it's 4.10 net then I'd say it's on the big side, but you need to find out what the net volume/tune is...
  9. #9
    Lakota's Avatar
    Lakota is offline Doesn't Know $hit
    Feb 2005
    Louisville, KY
    25
    6,232
    That's about the size that I would put a 15 in for daily lol
    Ben Hemp
    1992 GMC Sonoma Ext Cab NEW BUILD
    2008 MECA S1 KY State Champion, 151.0 dB
    2008 MECA S1 WorldChampion, 151.8 dB
    2010 MECA scores: 150.9 dB S2, 151.6 dB S3
    Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
