Results 1 to 7 of 7
Reload Thread: Building a sealed and ported enclosure...
    Aurorav8's Avatar
    Aurorav8 is offline CarAudio.com Elite
    Apr 2003
    Fort Wayne
    34
    1,610
    I got my MDF today, and have plenty to make two boxes. So I'm going to build a sealed enclosure that I know I can successfully make, and use.
    I would like to build a ported box with the extra MDF, just to see if I will like it better. But need some major help/advise with building.
    It will be housing a 12" Brahma, with approx. 850 watts running to it. I don't want to use a round port, but have no idea how to go about building a slotted port, or what to tune it to.
    I want to keep a nice balance of SQ and SPL, so 50/50 pretty much...or maybe even 60(spl)/40(sq). So I figured something like 32~36?
    I've been told how to generally start on the slotted port, but I'm lost after that. I was told to pretty much make a sealed enclosure that is 2.9 cu. ft. and then go about cutting out the holes for the ports and the sub. But that figure was for round ports.
    Any help with port length and size would be greatly appreciated.
    Mercureie's Avatar
    Mercureie is offline Stay in S-C-H-O-O-L
    Sep 2002
    Cleveland, OH
    26
    253
    you can download winISD pro, i know someone on here knows where from. it will help calculate port length and give you response curves so u can play around till u get the one u like. sometimes this program can be kinda off so u might wanna check it manually with the formula on the jl audio website.
    Car:'02 Nissan Xterra
    HU: Premier DEH-4400
    Comps: SPR-176A type-r 6.5's
    Comp amp: Zapco reference 200
    Sub:Re 15HC
    Sub amp: Hifonics Bx1000
    Box: 2.5 cuft sealed
    Aurorav8's Avatar
    Apr 2003
    Fort Wayne
    34
    1,610
    I got WinISD Pro downloaded, but I am lost with it...call me WinISD stupid.
    I just need to know how long and wide to build the port and how to go about building it, as I've never built a box before.
    Mercureie's Avatar
    Sep 2002
    Cleveland, OH
    26
    253
    alright lemme see if i can send ya a file with specs for ur driver. gimme a min. to whip somethin up
    Sub:Re 15HC
    Mercureie's Avatar
    Sep 2002
    Cleveland, OH
    26
    253
    do you, or anyone for that matter, know how much port area adire rec. for the brahma 12?
    Sub:Re 15HC
    Mindspin311's Avatar
    Mindspin311 is offline Member
    Dec 2002
    ATL Suburbs
    28
    135
    What amp are you using the power the Brahma, just curious Im trying to gather some option for my Brahma that I will be getting.
    Aurorav8's Avatar
    Apr 2003
    Fort Wayne
    34
    1,610
    Either an Avionixx AXT800.2 or a Hifonics BX1000d...haven't quite decided yet.
