Results 1 to 7 of 7
Reload Thread: 1.5" Slot Port....Cause port noise????
    Jun 2002
    Chicago,IL
    30
    603
    I have a box and can only fit a slot port that is 1.5 inches x 14.6 inches and around 7 incehs deep. I will be putting 2 12" RE SE's in the box and it is 3.2 cubic feet. Will I have port noise or should I be ok?
    98 Grand Cherokee Limited 5.2L
    H/U: Alpine
    Speakers: Polk 6.5" GXR
    Amp: Hifonics BX1500D
    Subs: 2 12" RE SE's
    Box: Custom 3.3 Cubic foot ported
    Box tuned to 35 Hz
    In The Making: 5.1 cubic foot Box
    Ported to 28 Hz with
    Pluged Port (35 Hz)
    _____________________________
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: 1.5" Slot Port....Cause port noise????
    winISD would need a power figure to determine port velocity. Most say 25m/s is minimum, some say 35m/s can't be heard.
    Your port tuning would equate to 40Hz.
    Anyhow, with 1000w, there will be port noise (nearly 50m/[email protected]), and at 500w, speed reduces to 35m/s.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    F150Matt's Avatar
    F150Matt is offline Senior VIP Member
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    You need more port area for two of those subs anyways...
    Matt Sibley
    Dad, Electrical Engineer, MBA
    Used to do these:
    Team S.P.E.A.D. Captain
    Team Kicker
    Team Maxxsonics
    USACi Pro Stock 5001+ World Record Holder
    Miller's Avatar
    Miller is offline $
    Jun 2002
    Chicago,IL
    30
    603
    how wide minimum should my port be...I have limited width. My box is only 29.5 inches wide and i'm putting 2 12's in it and I need the port in the front. what should the Minimum port width be??
    H/U: Alpine
    Subs: 2 12" RE SE's
    Box tuned to 35 Hz
    Pluged Port (35 Hz)
    F150Matt's Avatar
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    Make the width of your port 2''...that'd give you like 29.?square inches of port. That would be a lil better. Sorry to alarm you, I was thinking your port was only 14x1 for some reason and its not so..you'd probably be alright with what you've got but 14.6x2 would be even better. JMO.
    Matt Sibley
    Used to do these:
    Team Kicker
    Team Maxxsonics
    Miller's Avatar
    Miller is offline $
    Jun 2002
    Chicago,IL
    30
    603
    I'm not sure if I have enough room for a 2" wide port, so I might try to squeeze in a 1.75" port and a 2 if possible.... will 1.75W x 14.6H x 12" Depth be ok with port noise for 2 12" SE's. I would prefer to do 1.5"W x 14.6H x 12" Depth, but which one would be better. Is the one with 1.5" gonna cause port noise??? how about 1.75"???
    H/U: Alpine
    Subs: 2 12" RE SE's
    Box tuned to 35 Hz
    Pluged Port (35 Hz)
    F150Matt's Avatar
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    It would probably be ok, go with whatever you can fit. Test it and see, thats the only way.
    Matt Sibley
    Used to do these:
    Team Kicker
    Team Maxxsonics
