Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Reload Thread: help please
    EPanther99's Avatar
    EPanther99 is offline Senior VIP Member
    Feb 2002
    Elizabethtown KY
    32
    306
    help please
    ok i am going to get a vented box and i was wondering if this box looked good size wise for a 12" L7 i want to order it but i just wanted to see if anyone thought it may not be a good size to use, thanks
    John
    http://cgi.aol.ebay.com/ws/eBayISAPI...category=14945
    HU: Pioneer Premier P-720
    Front: JVC 2 way 6.5" component system
    Rear: Kenwood KFC-1687
    Subs: (2) 2002 Kicker 15" L7's
    Amps: (2) Infinity Beta Digital 300's
    (2) 1 farad Stinger Power Caps
    (2) 1 farad Monster Cable Monster Caps
    violator5spd's Avatar
    violator5spd is offline Post Wh0re Hunter
    Oct 2002
    Ohio
    27
    1,795
    It looks fine to me...but I wonder what it's tuned to?
    - John (AIM - ViolatorJF)
    2000 Dodge Neon
    DEH-P9300, JBL BP600.1, eD15A.22 in 2.5^3ft sealed
    EPanther99's Avatar
    Feb 2002
    Elizabethtown KY
    32
    306
    im not sure, what does the different tuning freq. do to the sound of the sub? i havent had a ported/vented box in like 7 or 8 years my last one was a ported box with 2 12" MTX terminators so i never really messed with them before....
    Oct 2002
    Ohio
    27
    1,795
    In general, the lower the tuning frequency then the deeper that bass, and the higher the frequency, the more "boomy" it will sound. I'd bet it's tuned between 36 & 40hz, which isn't bad for an L7.
    2000 Dodge Neon
    Randy Savage's Avatar
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    well, in general, a higher tuning will yield higher SPL levels at it's peak, but will leave you with a peaky response and not too good of low end extention....
    When tuning lower, you will have a flatter response, but you will lose that high peak...
    Basically, lower tuning (IMO 25-33 hz) will yield nice SQ, and 34+ will yield higher SPL levels (this is just a general idea of frequency ranges).
    EPanther99's Avatar
    Feb 2002
    Elizabethtown KY
    32
    306
    i just emailed the company and asked what it was tuned at, accroding to kicker the L7 is supposed to be a lot louder in a vented encloser then in a sealed box, they also reccomend using a 25hz sub soinc filter to increase the power handling so i proabably wouldnt want to tune it at liek 25-30hz bc it seams liek it would take a way a lot of the output, i guess also if i dont liek the sound of it in that box i can always get a sealed box for it, thats what i had my 15" L7s in and they sounded good.
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    a sub sonic filter won't increase anything, it will just protect the driver from killing it's suspension at frequencies under the tuning...
    EPanther99's Avatar
    Feb 2002
    Elizabethtown KY
    32
    306
    well an L7 can handle 750 rms but in a vented encloser without a subsonic filter it can only handle 400 rms....
    "recommended power range 75-750 watts RMS with the use of an optional 25Hz subsonic filter; otherwise 75-400 watts RMS"; Kicker Web site
    also a vented box increases the sensitivity of the L7 in a sealed box it is 87db and in a vented enclosure it rises to 93db.
  9. #9
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    Well, this is what happens. When you go below the boxes tuned frequency, the subwoofer has to rely on its own suspension to control the driver...which can cause damage with lower power levels than the sub is even rated for...
    So, you are saying, that if I put an L7 in a ported box, tuned it at 30 hz or so, gave it 750 watts, and played a 35 hz tone it would blow?
    All a SSF does is cut off the frequencies under which it is set at...it does not increase/decrease a drivers power handling...
  10. #10
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    35
    7,770
    46
    and that's what snova's trying to tell you...
    a subsonic filter will protect the subwoofer itself, so you can send more and more watts to it without the need to care about the subs going into over-excusrion. RMS 75~400w would probably mean that the subs will operate within it's limits, so it's safe without a subsonic filter.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
  11. #11
    EPanther99's Avatar
    Feb 2002
    Elizabethtown KY
    32
    306
    i am not saying it cuts down the subs power handling, im saying KICKER...who makes the speaker says you should use one.....i know what a ssf is...i also know what it does...without one in the vented bx you will get exsesive port nosie due to the fact that the speaker will be moving so rapidly to create the low freq, and yes i know it has to rely on its on suspension it owuld be acting almost like a free air speeaker, but it still definatly increases the sesitivity of the sub bc it uses the power more efficently....and about the wattage to blow the speaker, i dont know, i was just coping exactly what the Kicker web site wrote...
  12. #12
    EPanther99's Avatar
    Feb 2002
    Elizabethtown KY
    32
    306
    i know its safe to use one without one, but not at very high power, im going to be putting about 900-1000 watts rms to the sub so i just assume not spend another 180 bucks to buy another L7 just bc i didnt want to use the filter....the whole reason for this post was just to see if anyone thoght that box in the link would be alright for the L7
  13. #13
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    35
    7,770
    46
    I don't think ssf's are meant to reduce prot noise either, although it MIGHT help, since 20Hz would mean a lot of air moved.
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
  14. #14
    EPanther99's Avatar
    Feb 2002
    Elizabethtown KY
    32
    306
    like i said im not just pullin this stuff out of thin air its all on kicker website and in the manuals for the speakers....but you answered your own question about not cutting down ports noise....20hz would be a ton of moving air whichin coming through the prot would be a lot of noise but if it cant get it to make it then there is no noise from it...
  15. #15
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    35
    7,770
    46
    port noise would not be heard if you calculate correctly and try to get port velocity under 25m/s. Usually, a slot port would suffice, as they can be large, but also, the larger the port, the longer it gets.
    Try to tinker around in WinISD pro, with both the cone travel and rear port velocity in mind.
    THe ssf will simply cut anything under the set frequency.
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
