Results 1 to 6 of 6
Reload Thread: I've got a question for you guys...
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    31
    21,086
    2 Post(s)
    457 Post(s)
    I've got a question for you guys. I just recently got the 21" Autotek sub running off of a SAZ-1500D, and I've been running tones though it, testing it out a little.
    I notice that when I'm doing the tones near full volume, or I guess near as loud as I'd be comfortable playing it, the cone starts to slowly oscillate at about 2 cycles per second, as well as playing the tone. The oscillation probably has 1/2" p2p movement.
    Is this an effect from having too large of a box, where there isn't enough of an air spring to keep the cone in check? With the 1500 watts I'm running right now, I can damn near make the sub reach mechanical limits, even right around tuning. So I'm thinking that shrinking the box down to 7 cubes, from 8.5 cubes, would do it some good....what do you think?
    2,500+ designs since March 2011
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Re: I've got a question for you guys...
    It sounds like cone breakup because the cone is too big for its own good. Cone rigidity is insufficient for the size of the cone. There's a reason that 18s are usually the biggest subs made. For a bigger cone, rigidity must increase exponentially with cone diameter and mass must increase exponentially as well to achieve this. Heavy moving mass reduces the sub's efficiency so big subs are usually underbuilt for their size (there are notable exceptions).
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    Mar 2007
    saint charles, IL
    26
    10,311
    Quote Originally Posted by helotaxi View Post
    what he said
    kovemaster559's Avatar
    kovemaster559 is offline Official LOW BALLER!
    May 2008
    FRESNO ,CA
    6,086
    he sounds rite
    MYSPACEhttp://www.myspace.com/eargasm559
    MY FEEDBACKhttp://www.caraudio.com/forum/showth...96#post4669596
    PM ME IF YOU NEED CUSTOM WORK DONE FOR YOU(E.I, DOOR PODS, PANNELS, KICK PODS, anything FiberGLASS
    Feb 2006
    Rockwall, TX
    31
    21,086
    2 Post(s)
    457 Post(s)
    so cone breakup by itself will cause it to slowly oscillate like that? Is there anything else that could be the issue?
    helotaxi's Avatar
    Dec 2003
    42
    8,933
    Not likely. Making the box smaller will exert more force on the cone and make matters worse, not better.
