Results 1 to 11 of 11
Reload Thread: ported downfiring enclosure.
    David12460's Avatar
    David12460 is offline Member
    Dec 2007
    Minnesota
    99
    is there anything you need to do different when designing a ported downfiring enclosure? I searched but did not find any answers regaurding ports.
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    Re: ported downfiring enclosure.
    Make sure it's at least the ports width away from the floor? I think thats all, if that..
    mapolley07's Avatar
    mapolley07 is offline its all imaginary
    Apr 2007
    Georgetown College, KY
    24
    1,142
    Quote Originally Posted by miker View Post
    correct me if i'm wrong, but wouldn't the floor act as another port wall and affect tuning? increase the length of the port and lower the tuning frequency?
    Quote Originally Posted by captaincheesey View Post
    I don't know because I am blindfolded and tied to the bed. I think I hear the clothes washer in the background sometimes, so maybe she is looking at laundry? Idk
    David12460's Avatar
    Dec 2007
    Minnesota
    99
    if I gave it about 3'' of breathing room do you think it would be ok?
    David12460's Avatar
    Dec 2007
    Minnesota
    99
    could I put the L shaped port facing up and the sub down?
    Kold_Killa's Avatar
    Kold_Killa is offline CarAudio.com Elite
    Apr 2007
    Little Rock, AR
    1,489
    Quote Originally Posted by David12460 View Post
    For sure...
    '98 Ford F150 Ext Cab
    Refs: gHoStFacE - its_bacon12 - 18inchjeepin - wu501
    Alpine CDE-9881 - Cadence TXA-3002 - Cadence TXA-1000d
    Mach 5 IXL 10 1cuft 40hz - CDT CL-61A
    David12460's Avatar
    Dec 2007
    Minnesota
    99
    So it does not matter if the subwoofer is mounted on the same side the Port side #2 is?
    I was not sure if that effected the tuning in any way.
    Kold_Killa's Avatar
    Apr 2007
    Little Rock, AR
    1,489
    Not quite sure what you are asking... If you are asking is it okay to have the subs mounted on a different face than the port, then yes... that is okay.
    I used to believe always put the port on the same face as the woofer, and still pretty much believe this for an SQ system... For SPL/SQL i don't feel it is necessary.
  9. #9
    David12460's Avatar
    Dec 2007
    Minnesota
    99
    ok to clear up my question look at this link. http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
    the back wall is where port wall 2 runs parallel with. I also want mount the subwoofer on the same wall.
  10. #10
    rain377's Avatar
    rain377 is offline Senior VIP Member
    Dec 2002
    Detroit, Michigan
    28
    316
    just remember that the closer the sub is to the opening of the port the more free air the sub is. i would go subs down and port back to get the most reflection possible.
  11. #11
    David12460's Avatar
    Dec 2007
    Minnesota
    99
    So with a L shaped port keep the port opening on the same side as the woofer?
