Results 1 to 11 of 11
Reload Thread: help with box?
    droskis's Avatar
    droskis is offline Member
    Oct 2007
    tampa
    132
    help with box?
    alright measured my trunk i have
    H=11.5 in
    W= 35 in
    D=25 in
    it calls for a 1.25 cu box for a diamond d6 10" and i have two so does this mean i need a 2.5 cu box?
    the above only gives me 1.9 cu. should i go sealed or maybe build it at a slant to get some more cu???
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    Re: help with box?
    yeah.. with a port and sub displacement... You'd have enough room fro one..
    droskis's Avatar
    Oct 2007
    tampa
    132
    Re: help with box?
    not enough for two?
    droskis's Avatar
    Oct 2007
    tampa
    132
    Re: help with box?
    if my calculations are right thats 5.8 cu?
    jdawg's Avatar
    jdawg is offline CarAudio.com Veteran
    Jun 2006
    Maryland, United States
    8,608
    1 Post(s)
    Re: help with box?
    I get 5.8, of course this isnt in inside of the box or account for port and sub displacement. Your maff is off.
    refs
    woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
    droskis's Avatar
    Oct 2007
    tampa
    132
    Re: help with box?
    how would i calculate that then?
    rain377's Avatar
    rain377 is offline Senior VIP Member
    Dec 2002
    Detroit, Michigan
    28
    316
    Re: help with box?
    L*w*h/1728=cuft
    droskis's Avatar
    Oct 2007
    tampa
    132
    Re: help with box?
    yes and thats 5.8 cu
  9. #9
    dleccord's Avatar
    dleccord is offline CarAudio.com Veteran
    Oct 2005
    Sacramento
    5,953
    Re: help with box?
    the internal space is about [33.5W x 10H x 23.5D]/1728 = 4.55ft^3 before driver displacement, that is sealed.
  10. #10
    BrianChia's Avatar
    BrianChia is offline CarAudio.com Elite
    May 2007
    Knoxville/Nashville TN
    1,292
    Re: help with box?
    It will work, I actually did a design a while ago that almost fits those dimensions. It is 2.5 cf @ 30hz.
  11. #11
    miker's Avatar
    Oct 2007
    Wayzata, MN
    5,326
    Re: help with box?
    I just read that you said you had 1.9cubes??????
