Results 1 to 12 of 12
Reload Thread: 2 Noob Box Questions
    Roid_monkey's Avatar
    Roid_monkey is offline Member
    Apr 2008
    Kelowna, BC
    42
    1) In my other thread i asked about sealing the port, and found out if the rest of the box is sealed you don't have to, but how do you seal (in the port) the wall of the box? Like in what order do you do what to make sure it is good to go (in an l-port box)?
    2) Should you pre-drill your screw holes before glueing, or when the glue is drying, or when the glue has dried, and also when do you put the screws in (again, in what order).
    Thx in advance and sry for any spelling mistakes its late and i don't want to work tomorrow morning so i'm angry
    SPY's Avatar
    SPY
    SPY is offline CarAudio.com Veteran
    Jul 2007
    NY
    5,222
    Re: 2 Noob Box Questions
    Quote Originally Posted by Roid_monkey View Post
    Build the bottom and outside walls first, then seal them all then assemble both pieces of the L-port outside the box. Once you have that done put the port into the box. Put the top on last and you can seal the top through the openings for the subs.
    2) Should you pre-drill your screw holes before gluing, or when the glue is drying, or when the glue has dried, and also when do you put the screws in (again, in what order).
    Place pieces in position and clamp, pre drill the screw holes. Take the pieces apart and apply plenty of glue, reassemble and screw together immediately
    Apr 2008
    Kelowna, BC
    42
    ok thank you. 3 more noob questions
    1) Would it be ok to drill small holes to run the wire through (if you sealed it) instead of using terminal cups?
    2) Whem mounting the subs and amp on the box, is it ok if the screws you mount them with stick through the mdf?
    3)Is it ok to mount the amp on the box?
    dman4486's Avatar
    dman4486 is offline RememberedHowToChangethis
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    #1 i ran my wire through the mdf and sealed it sounds great
    #3 yes...mount your amp to your box with rubber bushings
    Autos:
    '12 Audi A3 S-Line TSI 6MT
    '96 Honda Passport 3.2L v6 4X4 5sp
    2015 Victory Cross Country Tour 106
    2015 Ford Escape Ecoboost
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Rubber bushings make no diff unless you use bolts/locknuts, so the amp is NOT tightened to the box, otherwise the vibrations are still transfered through the mounting points.
    But most guys just bolt right to the box with no problems...
    Apr 2008
    Kelowna, BC
    42
    ok thanks guys, but is it ok if the xcrews mounting the subs stick through to the inside?
    dman4486's Avatar
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    preferably no
    Autos:
    tee's Avatar
    tee
    tee is offline You know
    Jul 2007
    BR
    550
    Sorry to jack thread, but while you're at it, is it okay to drill the screws holding the sub through the wood?
  9. #9
    dman4486's Avatar
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    Quote Originally Posted by tee View Post
    they are permanent.....make no difference
    Autos:
  10. #10
    BrianChia's Avatar
    BrianChia is offline CarAudio.com Elite
    May 2007
    Knoxville/Nashville TN
    1,292
    Yes, but if you are going to be removing or replacing the sub frequently, you can use T-nuts or the like.
  11. #11
    dman4486's Avatar
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    Quote Originally Posted by BrianChia View Post
    I have thought about this, but what happens when i go to install a different sub in my box and the holes don't match up
    Autos:
  12. #12
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    The sub comes down and covers them up anyway...
    A real easy way to build a box is use a brad nailer. Just glue it together, then nail it to hold. Once its all together, go back and put screws in it to really stick it and bring all the wood together for a perfect fit.
