Results 1 to 5 of 5
Reload Thread: 15" HDC3 Box design- does this look O.K to you?
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    One of my friends is getting an 15"Audioque HDC3 pretty soon. It's going to go in an older Chevy Caprice. He wants me to build the box for him, but i've never designed a ported box before. I used the RE enclosure calculator and came up with this design
    width-32", height-18", depth 19" , port 16.5" X 4" X 14.25" long
    It ended up being 4.2 cubes tuned to 38 hz, how does this design sound to you guys? I just wanted to check here first before i started building because i wasn't sure how accurate this program was since i've never used it before. Thanks
    WOT's Avatar
    WOT
    WOT is offline Banned
    Nov 2007
    Toronto,CANADA
    3,667
    Re: 15" HDC3 Box design- does this look O.K to you?
    Its very accurate if you build the box to exact spec and use the same thickness wood you enterred in the program
    bhsdriller's Avatar
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    ok thanks, does anybody else have any experience using this program?
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    31
    21,086
    2 Post(s)
    457 Post(s)
    I use winISD to model my boxes and the calc over at carstereo.com for overall volume and port lengths. As long as your dimensions are right, it should be fine...
    2,500+ designs since March 2011
    WOT's Avatar
    WOT
    Nov 2007
    Toronto,CANADA
    3,667
    Wheres this calc @ carstereo.com for the volume and such? cant find it
