Results 1 to 5 of 5
Reload Thread: need some help with truck box
    shiver's Avatar
    shiver is offline Junior Member
    May 2003
    mass
    ok i need a little bit of help here, cuz im confused as hell on this. i have a 2000 dodge ram extended cab. the dimensions under the rear seat are:
    Length - 45"
    Height - 10"
    Depth - 16"
    The thing im having trouble with, is that under the seat, it is not a flat surface, from front to back it elevates, would this be a problem? i don't know whether or not i should go with the subs and amp or just get an Infinity Basslink, i'd rather have the subs and amp. Thanks for the help though.
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    34
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: need some help with truck box
    Length - 45"
    Height - 10"
    Depth - 16"
    Just build a box that fits. The box doesn't have to be a perfect rectangle/square, just as long as there is enough airspace for the subs. Although the 10" height is gonna be tough to overcome unless you put some spacers under the seat bolts to get some more clearance under there.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    Yeah i agree with tommy, your only problem would be the 10 inch clearance you have. One way to clear that issue is to use some 8" subs i.e. eclipse subs. That angle going toward that back my cause issues but im not quite sure of how it is configured so i really cant give any advice on that issue.
    shiver's Avatar
    May 2003
    mass
    alright, thanks for the help. i think i might just get an mtx pre-made truck box, it says to fit perfectly, so i'll try it out. but thanks for the help.
    ActionJ-01-Z71's Avatar
    ActionJ-01-Z71 is offline Action Jackson
    Jan 2003
    TULSA
    42
    237
    14
    could build the box with the subs firing down. here it sounds kick *** in ex cabs.
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    Alpine Type R 12 4ohm DVC
    Kicker XS-100 @ 2 ohms
    BOOMER!!!!!
