Results 1 to 9 of 9
Reload Thread: Same setup with two different design specs WTF?
    Qbenjamin's Avatar
    Qbenjamin is offline CarAudio.com Veteran
    Jan 2007
    Tampa
    3,517
    11 Post(s)
    I had two different designs done by two totally different designers. Well, the trouble that the box depth (Box A) is a bit much for me to give up on one, and the other (Box B) seems to be too small. Not to mention that it has no bracing internally.
    Box A (Was designed to have a plexiglass front)
    Specs on this box are 36"(W) - 17"(D) - 16.5"(H)
    http://i194.photobucket.com/albums/z...inalcorner.png
    Box B (Basic dual box)
    Specs on this box are 36"(W) - 12.5"(D) - 15.5"(H)
    http://i194.photobucket.com/albums/z...Attachment.jpg
    Neither box has a double baffle for the subs, but I normally go with internal bracing. Any help would be appreciated, as I really don't know which design I should use.
    Sold to Ref's: IonSQL; envengineer; BAD_MAYHEM; oxsign; dvrmstrng; corto; wong05tsx; mrdurden; dirtyg; Cheesemind; gladiator_jai; bumpincrv; nycking23; slikvik; Mr.Ronin_2U
    Traded with Ref's:: Spike_e; jnoel; Sundownz
    Stock H/U; AudioControl Lc6i; Alpine PDX-V9; Focal Components & Coaxials; JL W6v2; Ported Enclosure @ 32hz; Second Skin Damplifier Pro
    What sounds good to you, may sound like crap to me...
    SPY's Avatar
    SPY
    SPY is offline CarAudio.com Veteran
    Jul 2007
    NY
    5,222
    Re: Same setup with two different design specs WTF?
    Is this box ported?
    I don't see a port opening but it looks like there is a port wall inside?
    Also no one can tell which one is the right one if we don't know what your looking for.
    Post up what subs you are using along with desired box vol and tuning if going ported.
    Qbenjamin's Avatar
    Jan 2007
    Tampa
    3,517
    11 Post(s)
    Quote Originally Posted by SPY View Post
    Is this box ported?
    Yes, that box is ported.
    Subs are 2 Polk SR 10D4's.
    Max dimensions are:
    W - 36"
    D - 17" (Less = Better)
    H - 16.5" (Less = Better)
    Desired tuning 30-33hz......
    mobeious's Avatar
    mobeious is offline what does 0hz feel like?
    May 2004
    Bartow, FL
    4,839
    26
    2 Post(s)
    the second one is 2.32 cubes after port displacment
    the first one is 4.48 befor any displacment being i cant tell what the port is
    with those subs i would shoot for 1.3-1.5 cubes per sub at 32hz
    Alpine CDA-9833
    (2)sets Cresendo ccx65
    Box Engineer for
    Qbenjamin's Avatar
    Jan 2007
    Tampa
    3,517
    11 Post(s)
    Quote Originally Posted by mobeious View Post
    So which should I use?
    Qbenjamin's Avatar
    Jan 2007
    Tampa
    3,517
    11 Post(s)
    Specs on that second one are as follows:
    Port piece # 1 9.25" X 14
    Port Piece # 2 9.75 X 14
    Port Width = 1.75"
    Port area = 24.5"
    Port Length = 21.75"
    Qbenjamin's Avatar
    Jan 2007
    Tampa
    3,517
    11 Post(s)
    This should help out for the spces on the bigger box.....
    Oct 2007
    239, Florida
    30
    1,931
    4 Post(s)
    If you are not going to use the plexi, i will re-design it to accomodate the change, the only reason i had to do the vent that way was due to the Plexi.
    Team Decent Member
  9. #9
    mobeious's Avatar
    May 2004
    Bartow, FL
    4,839
    26
    2 Post(s)
    here ya go 2.8 @ 33hz
    Alpine CDA-9833
    Box Engineer for
