Results 1 to 9 of 9
Reload Thread: how do u measure a fiberglass box before u build it
    nismboy6986's Avatar
    nismboy6986 is offline the **** technician
    Jul 2002
    Belhaven NC
    665
    how do u measure a fiberglass box that conforms to the contours of your car before u build it. the only i can see to measure a enclosure like this is to pour water into it and then measure the water after u pour it back in some big graduated cylinder or something
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    i would like to know this, there r gotta be some other way besides using water or sand.
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    other than estimating...thats probably one of the most accurate ways to do it.....jus figure out the volume of a given amount of water or sand and fill it up and measure how much u put in........sorry.........
    Mark_ab's Avatar
    Mark_ab is offline The Alpha Male
    Feb 2002
    Edmonton, Alberta
    35
    4,213
    5 Post(s)
    Measurements, and a rough estimation is the best you can do until the box is actually built.
    Is this not a reasonable place to park?
    awalbert88's Avatar
    awalbert88 is offline Blame Canada
    Oct 2002
    Lancaster, PA
    34
    1,342
    Well, if it's possible, fill a plastic bag with styrofoam peanuts or something and work it into the area you're going to make the box in. Might have to use some cardboard to support it, depending on the shape. Other than that, there's not a lot of stuff you can do short of estimation.
    JL Audio 12W7, JBL BP300.1
    1993 Mercury Capri XR2
    1998 Ford Mustang
    1989 Audi 100 Quattro
    2000 Buick Regal GS
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    The way I alwasy use. Is to figure out the largest box I can fit into the space. Then use some packng peanuts to fill in around the edges. Then figure out the volume of the peanuts. And combine that with the volume of the box.
    5 % equipment
    90 % install
    5% beer
    Sspider's Avatar
    Sspider is offline CarAudio.com Elite
    Feb 2002
    new york
    648
    geez, thats a grat idea...
    so you would see the space of taken up by the box, and in the contours just stuff the bags full of peanuts?
    sspider
    ............under construction.......
    AIM CisKO4u
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Yep. That's the easiest way I have found.
    5 % equipment
    90 % install
    5% beer
  9. #9
    audiomoney's Avatar
    audiomoney is offline Junior Member
    Jun 2003
    that city in PA
    43
    26
    me too.
    A wise man once said..."It's all fun & games , 'till someone loses an eardrum."
