Results 1 to 11 of 11
Reload Thread: (2) MA HK12x2 Custom box Design help...
    NissanKicker's Avatar
    NissanKicker is offline Honda-on-22-Nissan-on-20
    Oct 2007
    Ruston/Grambling, LA
    29
    1,420
    23 Post(s)
    Icon14 (2) MA HK12x2 Custom box Design help...
    Hey, I have everything that I need as far as on paper... I was just wondering if ANYONE ( Knowledgeable ) could give me anymore advice, pointers, or point out something that might go wrong with this design.
    ... I REALLY WOULD LOVE FOR SOMEONE TO SKETCH ME A MODEL... I REALLY WOULD APPRECIATE IT!!!!!
    HERE WE GO!
    MA HK12x2 Spec'd enclosure ( Ported ):
    Cuft: 3cuft
    Hz: 38hz
    Sq Port: 4x4
    Sq Port Length: 14.5"
    Number of Ports: 3
    Max Dimensions ( 99 Nissan Sentra ):
    External Dimensions: 42"L x 22"D x 14"H
    Internal Dimensions: 40.5"L x 20.5"D x 12.5"H
    SUBWOOFER CUTS!
    (2) 11.5" for the sub holes...
    BOX CUTS!
    Top: 14 x 42 x 22
    Bottom: 14 x 42 x 22
    Front Wall: 42 x 12.5
    Back Wall: 42 x 12.5
    Left Side Wall: 20.5 x 12.5
    Right Side Wall: 20.5 x 12.5
    * NOTE *
    ... Front wall will have the three ported centered on the bottom, in the middle.
    Example:
    2 Ports will be on the bottom in the middle, and the third will be centered in the middle stacked on top.
    ( Think of a PYRAMID, and you'll get the picture )
    PORT
    PORTPORT
    ^^^^^^^ LIKE THAT.... Exactly!
    PORT CUTS!
    * Each port external dimensions is 4" x 14.5"
    Top: 4 x 14.5
    Bottom: 4 x 14.5
    Left Side Wall: 2.5 x 14.5
    Right Side Wall: 2.5 x 14.5
    * NOTE *
    Remember! There are 3 ports. All are IDENTICAL ( Triplets )
    To get DIRECTLY in the middle, it'll be:
    42" MINUS 8" = 34"...
    NOW
    34" DIVIDED BY 2 = 17" on each side of the ports
    To get DIRECTLY in the middle for the single stacked port, it'll be:
    8" MINUS 4" = 4"...
    WHICH MEANS
    2"s will be on each side of the stacked port, making it centered.
    TOTALING
    A PERFECT PYRAMID!!
    Here is a quick lil' sketch, to give you an IDEA of what I'm picturing in my head.
    Vehicle: 1999 Nissan Sentra GXE 4-Dr [ Lambo Doors ]
    Head Unit: Alpine CDA-124SXM
    Front Stage: Kicker DS6.5s w/ (4) Power Acoustik NB.4s - Rear Stage: (4) JVC 5-Way 6x9s
    Sub Stage: 18" FI Audio Q - Custom Ported Enclosure: 6.41 cuft Tuned @ 29Hz
    Sub Amp: (1) Kicker KX2500.1D - Highs Amp: AutoTek AT-1200.4
    Processors: Clarion EQ-746 & Clarion MCD-360
    Wiring: Install Bay 1/0 Gauge ( Including Big 3 Upgrade )
    Batteries: EverStart Maxx's ( 750 CCA ) In Front & Back
    DJ's Installation
    spl guru's Avatar
    spl guru is offline Fat Chicks Drool
    Feb 2008
    Mid-Illinois
    34
    698
    Re: (2) MA HK12x2 Custom box Design help...
    Looks neat, but maynot work well
    refrence- dbman150- skinner070-mobilecreations-JHughes-SPL2k-1phatclipse-Team H&K-woofercooker-
    85 blazer
    **coming soon**
    A Van.
    Oct 2007
    29
    1,420
    23 Post(s)
    Don't take this in the wrong way... Just asking:
    1) Why not...
    2) Explain...
    Anyone else????
    ... Thanks for the compliment also!
    DJ's Installation
    BrianChia's Avatar
    BrianChia is offline CarAudio.com Elite
    May 2007
    Knoxville/Nashville TN
    1,292
    A sketchup only looks pretty, but it looks like you have done all of the math and calculations already for the design. If you were careful and made sure to take everything into consideration when calculating the tuning and airspace, I don't see why it wouldn't work.
    Oct 2007
    29
    1,420
    23 Post(s)
    Hmm... about 4 days to come up with everything.
    .... Looked @ the factory recommendations, then converted the round ports to square ports. ( Not into the aero thing ).
    Hopefully someone will 3D it for me... If not, I guess I'll just have to build and see.
    DJ's Installation
    audioarsonal's Avatar
    audioarsonal is offline JaMarcus
    May 2007
    close to home...
    4,165
    1 Post(s)
    I have a pair of 12x2's right now for my setup.Did 3cube per chamber 1 4x14 port in each.Then I went less cubes common chamber bigger port and seen some good gain.Just build a couple boxes to see what works best for you, as I am running an SUV.
    And did you check on the SX thing???
    Bought from:whiteram,Pyro_by_nature,AudioXtremes,Slab,IA2
    Sold to:annarbor84,ssackett,tapout383
    built for:skeptikal,Raid3r89
    SHADY SELLER:memphisman00
    Subs:4 Incriminator Audio Death Row 15's
    amps: Memphis 4K
    [email protected]
    BrianChia's Avatar
    May 2007
    1,292
    Remember that a 4" round port is not equal to a 4" x 4" square port.
    Oct 2007
    29
    1,420
    23 Post(s)
    I know it's not... I used a conversion formula
    4" x 14" long port .... Take 1/2 of the port size & multiply it by itself.
    2 MULTIPLIED BY 2 = 4
    Now multiply 4 by PIE ( 3.14 ) = 12.56 Sq. Inches of opening EACH
    TOTALLING - 37.68 Sq. Inches of opening
    DJ's Installation
  9. #9
    Civic_boi334's Avatar
    Civic_boi334 is offline Senior VIP Member
    Jul 2006
    Montgomery Al.
    384
    is changing from L7s to those MA's in 12's worth doin???
    (this is my Civic, cosmetic makeover, ricer to eastcoast ryder) __________
    Headunit: Pioneer AVH5000DVD
    Amps: Alpine MRV-420, Clarion 3-way crossover,
    Kole Audio 3000D
    Comps: Alpine Type R 6.5 front. Polk Momo in the rear
    Subs: 2 IA Death Penalty 12's D2
    Electrical:Tsunami 0/1 ga. wiring from front to back,
    battery(Deka and g31), Big 3 in 1/0 ga
    5.6 cu.ft. ^ 33hz.
    ref's Goldtaz1
  10. #10
    Oct 2007
    29
    1,420
    23 Post(s)
    I think so...
    ... Considering that I've ran '06 L7 12s.... I mean, that hit hard, but I don't like the sound they have went it's alittle overpowered!
    ... there's a guy that ran (2) zx750.1 on (1) HK12x2... 1800+ rms. And it never distorted the way the L7 ( dual 2 ) did.
    DJ's Installation
  11. #11
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,775
    5 Post(s)
    1264 Post(s)
    Quote Originally Posted by NissanKicker View Post
    That's enough port area for a 3cube box. How big is the box going to be???
