Results 1 to 14 of 14
Reload Thread: 4 15s in a Focus, need HELP!!!
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    4,975
    4 Post(s)
    okay so here is the issue, I have my toy car's motor coming out the shop in the next few weeks. I need to fill space in the car with my stereo. I'm planning for 4 Powerbass L-15s in a ported box. Powerbass recommends 6 ft3. with my experience with the "recommended" box size, all the companies usually go a bit small. can I go to 7 or 8 ft3 or is that too big? should i look to go with just 2 b/c of the size of the vehicle? any help is welcomed.
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
    jmanpc's Avatar
    jmanpc is offline CA.com Nostalgist.
    Jan 2006
    Jacksonville, Fl
    25
    17,290
    Re: 4 15s in a Focus, need HELP!!!
    What kind of power?
    I always go by spec, because the company who makes the sub tends to know it best...
    2007 Red Ford Focus ZX4 SE
    - Clarion DXZ955MC -
    - MB Quart RSD216 - 2 MB Quart RWE-354 in 4 cubic feet sealed -
    - MB Quart DSC4125 - Audiopipe AP1500.1D - Optima Blue Top -
    Team High Sexage
    fasfocus00's Avatar
    Jun 2007
    New Orleans, LA
    4,975
    4 Post(s)
    I'm either gonna go with 1000.1D or 1500.1D per pair. the 1000.1D is 1000x1 @ 1ohms and the 1500.1D is 1500x1 @ 1 ohm. I just have to see what's stocked by my ppl.
    a little with the company knows best about their product. if you ever call 1 of these companies and asked them to recommend a box size and port they almost never give you the recommended sizes that are in your manual. I usually go 20-25% larger than the recommended. It worked pretty go for me so far.
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    Apr 2004
    Indy
    24
    19,672
    With 4 15"s and all the equipment necessary to run them effectively, your username might not fit anymore.
    fasfocus00's Avatar
    Jun 2007
    New Orleans, LA
    4,975
    4 Post(s)
    well the motor that i'm waiting on to put into the car is a small block ford 347 with a base 400+ whp on just motor and about 600+ whp on nitrous. I think I can still live up to my screen name, especially since the car is not suitable for the track and will not be able to fully compete in audio competitions. the only ppl that could really judge it are the street guys.
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,694
    Just wall it...
    fasfocus00's Avatar
    Jun 2007
    New Orleans, LA
    4,975
    4 Post(s)
    that's what i'm planning on just have 2 issues to deal with.
    Issue 1 is do I want to keep room for a roll cage?
    Issue 2 is how many cubes is necessary for this wall? separate enclosures?
    Sep 2006
    Tampa, FL
    7,694
    Forget the rollcage... If you build it solid enough you wont even need a rollcage.
    Post up some pics of the car. If you give me the box specs you wanna run the subs with I could design something for you. Probably 2-4 seperate boxes, depending on the shape and size of the car.
  9. #9
    BrianChia's Avatar
    BrianChia is offline CarAudio.com Elite
    May 2007
    Knoxville/Nashville TN
    1,292
    Why do you need a roll cage?
  10. #10
    basshedz06's Avatar
    basshedz06 is offline CarAudio.com Elite
    Dec 2007
    Tupelo, MS
    537
    why are u puting tha much power in a race car anyway i mean 4 15's in a focus dude come on your going to be putting 400hp down and god knows how much ft lb torque on the pavment and now u wanna go an put 4 15's in there. u have to think about the weight of it all just the box alone will prolly weigh over a 100lbs then add subs and amps and u know u have to have batts for all that thats bout anouther 100 or less pounds. then a roll cage!!! dont want to come off as like i am downing you but think about it just do 2 15's and see where how u like it, if not just find u another car, i would love to see how u get all that in that small of a car.
    TEAM DB DRIVEN
    keepin it real wit some gangsta ****
  11. #11
    Telegon80's Avatar
    Telegon80 is offline Senior VIP Member
    Oct 2006
    in my house.
    408
    Quote Originally Posted by basshedz06 View Post
    I agree.
    The car might be able to still go fast with the 400hp but it will be heavy and clumsy on the road.
  12. #12
    mdillon's Avatar
    mdillon is offline ummm......what?
    Nov 2007
    visalia
    772
    build the box around the roll cage, or inside of it. you can use the roll cage as bracing.
    also i dont think you have room for 4-15's
    '01 5.9 Dakota R/T
    HU: Pioneer Premier 680
    Front Stage: highs: B&G neo8 planars
    mid-bass: Hi-Vi Research 8" (x4)
    http://www.caraudio.com/forum/showthread.php?t=304095
    Subs: MB Quart Rwe304(x2)
    ported 4 cubes @ 30
    Amps: MB Quart Reference 4x50
    MB Quart Premium 1200.1D(1ohm)
    Quote Originally Posted by traksta15 View Post
    sad but true.....but remember, fat girls give better head cause they're always hungry.
  13. #13
    Dec 2006
    Oak Hills, CALI
    1,681
    he has room, i have a focus and had 4 15's non walled, at a point i was gonna do 4 18s but i woulda been squeezing it
    TEAM DEAFSQUAD
    TEAM POWERMASTER
    TEAM SPLZ
  14. #14
    wErd's Avatar
    wErd is offline Maker of All Good Threads
    Nov 2003
    usa
    5,491
    1 Post(s)
    yea maybe in a hatch focus, my sedan barely fit 5cubes.
    refs: viveet, dvrmstrng,velobard,pickup1,rumblebee2
