Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Reload Thread: How do I make a perfect circle
    morgans432's Avatar
    morgans432 is offline CarAudio.com Veteran
    Aug 2007
    new jersey
    2,719
    without using the jasper jig. I look over at realmofexcursion and that sticky is gone now for some reason. I really don't want to go out and get one of these for a one time thing. Pictures or anything would be awsome.
    Quote Originally Posted by BumpMW View Post
    I just want 2 subs that will rattle my eyeballs and soothe my ears at the same time. The type rs did that but didn't last.
    Quote Originally Posted by mprintz View Post
    Everyone here hates on audiobahn. They are a good company, but everyone here has rich daddies and can buy whatever they want. My friend blew out his back window of his F-150 with two Audiobahn Alum12s (2000 watt max each). Go with the bahn. **** you haters.
    Quote Originally Posted by jpd2621 View Post
    24 nuts holding each rim in, what other info can i give lol
    97gp's Avatar
    97gp is offline Banned
    Nov 2007
    ohio
    7,931
    Re: How do I make a perfect circle
    budahbuddy803's Avatar
    budahbuddy803 is offline CarAudio.com Veteran
    Feb 2006
    Clemson, SC
    4,708
    14
    how about just a regular jig saw? Make your circle with a protractor and then cut that bish out.... thats what i do and i have never had any problems.
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    40
    14,802
    ummm draw it then use a jig saw
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    morgans432's Avatar
    Aug 2007
    new jersey
    2,719
    I just got a router so I want to try that out I use to do the jigsaw but never really had great results with it.
    SethPhillips's Avatar
    SethPhillips is offline I'sa Playa
    Feb 2005
    Northern Utah
    28
    9,013
    15
    i allways use a circle jig w/ a rotor.. perfect holes for me!
    morgans432's Avatar
    Aug 2007
    new jersey
    2,719
    Quote Originally Posted by SethPhillips View Post
    Thats what I plan on doing just need to make a circle jig
    BrianChia's Avatar
    BrianChia is offline CarAudio.com Elite
    May 2007
    Knoxville/Nashville TN
    1,292
    Get some 1/4" MDF and the proper screws to attach to the base of your router.
  9. #9
    bjfish11's Avatar
    bjfish11 is offline FisherCustoms.com
    Aug 2005
    Garden Plain, KS
    27
    4,922
    Quote Originally Posted by BrianChia View Post
    Yes, this is how you can do it. You are essentially making your own jig.
    Authorized SSA Loaded Enclosure Dealer
  10. #10
    budget76's Avatar
    budget76 is offline fawkin' newb
    Mar 2007
    Monmouth County New Jersey
    469
    Just like they said, make your own. I made one a couple months ago. Took a bunch of careful measurements, and it worked out perfect. If you're building a decent box, you should easily be able to make one. Took me a while, because I didn't want to f*** it up, but it's easy. If you have no idea where to start, Google it. I found a good write-up to make sure the way I planned it was right.
    FWIW used 1/4" scrap wood ****. Cardboard would work in a pinch.
    PAST: 1976 International Scout. JVC head unit, pioneer 6x9's, Focal 5.25 comps, and a Kicker S12L7 in 3.25 cubes at 37hz: Crunch PZI 1500.1 amp at 1 ohm. 1/0 throughout.
    Replaced the factory 8 track and single 4x7 speaker behind the dash
    PRESENT: 95 325TI. JVC HU, 5.25" PG RSD, Sony Xplod 604EQX 4ch built in EQ, 10" MB Quart Discus in custom molded 'glass enclosure
    Refs: JLJunkieMX107/ HawaiianBassHed/ bk12321/NightDrifter05/Annao2485/nitro_freak1/tapout/juan_caliente/fasfocus00/TheFiverMan/Louisiana_CRX
  11. #11
    iDesignBoxes's Avatar
    iDesignBoxes is offline This many.
    Mar 2008
    USA
    453
    1. Threaded rod and one bolt.
    2. Drill hole in end of rod so that a nail or a screw will fit inside.
    3. Attach pencil to bolt on rod.
    4. You now have an adjustable circle marker!
    Shelby... I love you...!
    880PRS • Seas Neo Alums • Dayton RS-180 • 2x MAW-15 (SOON) • eD Nine.5
    AIM: iDesignBoxes
    E-Mail: iDesignBoxes@gmail.com
  12. #12
    bjfish11's Avatar
    Aug 2005
    Garden Plain, KS
    27
    4,922
    Im going to say I would not trust a piece of cardboard... LOL
  13. #13
    sqhertz's Avatar
    sqhertz is offline All Day Son..
    Sep 2006
    Miami ,Fl
    5,639
    4 Post(s)
    what about one of those 'all in one cutting tools'? like the rotozip? they do sell circle jigs for them...
    - Ref.s -
    ssbogger , derek9087 , mike dressure , xluben , brocken , QtrHorse , marley1 , byoon001 , IonSQL , Duke , TheBaron929 , SiX , Andar , blackbonnie , SPLV , dbaudio , dillinja666 , 97cavy , dropkick13 , TeamPSI , foreman , integra88 , bangincaraudio , spinelli , gkatmar , MustangGT25YRS , stockgp , FASTIMES , ultimate157 , Reson8 , vitveet , req
  14. #14
    bonesninja's Avatar
    Oct 2004
    Lima, Ohio
    40
    14,802
    Quote Originally Posted by sqhertz View Post
    thats what i use.....works great
  15. #15
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    Quote Originally Posted by bonesninja View Post
    X2! works really well.
    REFS:
    Sold to- Sky Deaner, Jeeper07, brazilianguy, bjl95mustang, Mr Wiggl3s, Ridinhi (x2), Pootie
    Bought from- kurtdirt1, jmanpc, doingstuffwell
    Traded with- DaGhost, Spooney
