Results 1 to 6 of 6
Reload Thread: Box help for two Shivas
    venom107's Avatar
    venom107 is offline The Graveyard Shift
    May 2002
    Independence, Kansas
    33
    607
    Hey guys I want to tune my box to 29Hz for two shivas. The measurements for the box are:
    31 inches across
    14 inches high
    24 inches deep
    So you have any ideas or tell me how I could constuct it? Im going to build it out of 3/4 mdf so Help on this would be appreciated.
    1996 Toyota Camry LE Gold Edition (customized)
    HU- Alpine CDA-9805
    Front-6 1/2 Alpine SPR-17LP
    Rear-6 1/2 Alpine SPR-17LP
    Subs- Audiobahn AW1200Q
    Amps- mids and highs 4 channel alpine 25rms X 4.
    Amps-Sub U.S Acoustics USX800D
    Custom Slot Ported Box
    Tuned to 30 Hz
    venom107's Avatar
    May 2002
    33
    607
    I forgot to mention
    I forgot to tell you that the box I want is slot ported tuned to 29Hz. I just need some measurements on how to seperate the subs and how big of a port I should use. I'm not going to any competitions so I just want the loudest daily driving subs I can get.:p
    HU- Alpine CDA-9805
    Tuned to 30 Hz
    more_spl's Avatar
    more_spl is offline only have 1, but it's 12"
    May 2002
    Winnipeg
    32
    1,108
    http://www.carstereo.com/help/Articles.cfm?id=31
    Use the second calc at bottom.
    don't put the subs in seperate chambers in ported..... a slight miscalc or cut will throw one side off... Just use one big chamber, it's ok when dealing w/ ported
    venom107's Avatar
    May 2002
    33
    607
    If one blows
    If one sub blows wont that cause the other one to blow also? Plus if I want to put each sub in a 2.8Cu Ft box do I just build a 5.6Cu Ft for both of them together? What are the calculations for finding out Cu Ft. I migh just build two seperate boxes so I can avoid some of these complications unless you could clear them up.
    HU- Alpine CDA-9805
    Tuned to 30 Hz
    venom107's Avatar
    May 2002
    33
    607
    Got a question
    Ok I figured out that I can fit a 5cube box exactly in my car so if I build a dual 12" box with no spacers and a single port I will put it in the center. Will 5 cubes be enough for 2 shivas tuned to 29Hz?
    HU- Alpine CDA-9805
    Tuned to 30 Hz
    more_spl's Avatar
    May 2002
    Winnipeg
    32
    1,108
    to find the EXACT internal Ft^3 of your box, use the sealed box calculator on
    http://www.eatel.net/~amptech/elecdisc/spboxnew2.htm
    It doesn't matter w/ this calc if you are porting it, it's close enough still....
    But ya. If you want the real formula for Ft^3, it's "(LxWxH) / 1728"...
    although that formula doesn't take into account for the thickness of wood you use.
    I've heard from many people, and everyone agrees that the single chamber for multiple vented subs is okay to use... I questioned the fact becuz it's improper to do w/ sealed, but you will be fine w/ 1 chamber... I would assume you're ok becuz are is escaping thru port as well so not as much push-pull on the subs if one blows....... idk
    i decided not to have a signature
