whats the best way to attach a plexi front on an MDF box, sealed enclosure, to ensure the front doesn't leak?
i would use some type of caulk. and hope that the plexi is thick enough.
when in doubt, check the ground.
1728
aol: ibarrg7
email: ibarrg7@aol.com
I used a foam weatherstrip that is sticky on one side, worked well for me.
make sure it is thick enough, my friend said his plexi cracked due to the amount of pressure being exerted
http://www.sounddomain.com/id/burtonsnow83
148.1 on the dash(rangerman's mic)
H/U -Alpine cda-9815
Comps- CDT Cl61a
Sub- 2 edk 12.44
amps- Avionixx AXT 800.2
Us acoustics usx2080
box - 2 cubes each at 33 hz
wiring-knukonceptz
All in an 02 xterra
Go to home depot, it's 3/4" wide and like 1/2" thick.
we're talking about plexiglass, not weather stripping.Originally posted by SirSteve
1728
aol: ibarrg7
Gotcha... BTW - the reason I used the weather stripping instead of caulk was in case something went wrong and I had to remove the glass to get to the speakers. I didn't want a big mess with the caulk. There are pictures of my box in the Photo Gallery (using 3/4" plexi for 3 JL audio 12w3v2-D4's with a JL 1000/1 pushing them.
Bookmarks
