Results 1 to 15 of 15
Reload Thread: New box and custom wire terminals.
    budget76's Avatar
    budget76 is offline fawkin' newb
    Mar 2007
    Monmouth County New Jersey
    473
    1 Post(s)
    Sparknotes: New twist on the bolt and ring terminal wire connection method. Look at pics to see
    Well, just made a box for the hell of it. No use for it right now, but what the hell. Wood was free, and it was during school, so why not. I used the plans for [email protected] I believe, from the sticky.
    Used 3/4'' Birch ply, which turned out to be a little less than 3/4", with Titebond 1 (I know, not 2, but it's what I had). Clamp, then countersink and predrill, then screw method. Had to cut all the pieces on the panel saw, the table saw motor died. Never remembered to bring the camera to get pics of the stack, or assembly.
    Anyway, made myself a circle jig, and i'll never cut a circle with a jig saw again VERY easy to make cutouts now. Gave the box 2 coats of clear, then ran out. The spots you see that don't look ''right'' are where the wood slightly warped, somehow, and I had to sand it perfect. Rounded off all edges with the router.
    On to the shining beauty of the box, the wire terminals. Probably took as long to make these as it did to assemble the box First time, had to work out the kinks. Would take me about 15minutes now. Took about an hour.
    I decided to use the bolt and ring terminal method, but didn't want the look of a bolt,nut combo on the outside of my box. Figured I could drill out something to screw on over the nut/bolt end to hide it. Look around the room, mini pool balls will work. Got a red (+) and black(-), even better! Steps, probably forgetting some things but you can figure them out. It's **** late
    1.Figure out what size drill bits I need to use, clamp them in the vice, and drill them out. The first section should be wide enough to clear the nut and cover it, then the next small enough to thread onto the bolt tightly, but not too small that you can't get it to thread on. Drill bit sizer works wonders here
    2. Mount bolt w/lock washer on inside of box, flat washer+nut on outside. Make liberally tight, then test fit pool balls again. Ball should cover all the nut, or most of it, and make it down to your flat washer.
    3. Now, using a very small drill bit (I used 3/32"), drill a hole through the bolt directly above where the nut is. You need to make sure your nut is as tight as you're going to want it. Don't overtighten to squish the wood, but you want to hear a slight ''cracking'' to know it's tight.
    4. Now, uninstall, and go outside and spray a coat paint of of red on one, and black on the other, so you can remember which is which when you take the balls off. Looks better than the gleaming silver as well. I used flat black, and a red primer I had left over from body work
    5. Re-install, this time with your wires attached inside with the ring terminals. Make sure there's no paint insde the hole in the bolt. I used the drill bit to scratch it all out.
    6. Insert the stripped and twisted wires into the holes in the bolt. Should strip about 3/4". Thread pool ball on, hold's the wires tight. I pulled with enough force that something like a thrown shoe would, didn't budge. The screws in the amp would let go first.
    7. Post pics on CA.com, giving me props This could be done with MANY things, pool balls are just what I had sitting around.
    BJ, feel free to steal my idea
    Pics in next post. Don't want to lose all this typing for some reason like a electric surge or something.
    PAST: 1976 International Scout. JVC head unit, pioneer 6x9's, Focal 5.25 comps, and a Kicker S12L7 in 3.25 cubes at 37hz: Crunch PZI 1500.1 amp at 1 ohm. 1/0 throughout.
    Replaced the factory 8 track and single 4x7 speaker behind the dash
    PRESENT: 95 325TI. JVC HU, 5.25" PG RSD, Sony Xplod 604EQX 4ch built in EQ, 10" MB Quart Discus in custom molded 'glass enclosure
    Refs: JLJunkieMX107/ HawaiianBassHed/ bk12321/NightDrifter05/Annao2485/nitro_freak1/tapout/juan_caliente/fasfocus00/TheFiverMan/Louisiana_CRX
    budget76's Avatar
    Mar 2007
    473
    1 Post(s)
    Re: New box and custom wire terminals.
    No, I didn't finish sealing the inside seams yet, that'll get done soon.
    I've got another trick idea on how to make the wires split from the amp to each ball. May do it tomorrow. If I do i'll post pics. I have NO idea what amp's gonna be mounted on this though, so it may not work as well as in my head. I plan on having the amp mounted on top of the box like my current install. Saves space, and I can run the wires cleanly up the side of the box in some split loom.
    evilkokonut's Avatar
    evilkokonut is offline Senior VIP Member
    Feb 2006
    Socal
    160
    lol wow those terminals are ghetooo
    Headunit: Pioneer P880
    Components: CDT CL-61A
    Amp: US Acoustics USX2100
    Sub: SI Mag 15" D2
    Box: 4.0 cf @ 30hz
    Amp: Viper D1200.1
    Immacomputer's Avatar
    Immacomputer is offline Cloud disappear
    Sep 2006
    Ocala/Oviedo, FL
    33
    4,672
    12 Post(s)
    Clever idea for the wire terminals but they look pretty goofy on that enclosure. Are you leaving it bare or painting it? Just adding clear would make that look ghetto as you don't have any nice grain to look at and the screws with filler also kill the appearance.
    Video 1
    I may make you feel but I can't make you think.
    Your sperm's in the gutter -- your love's in the sink.
    Video 2
    budget76's Avatar
    Mar 2007
    473
    1 Post(s)
    It's clear coated just to seal it up, but it'll get carpeted or painted if I ever use it. They do look kinda goofy, but I like it a lot better than a couple bolts sticking out the back. I think once the amp's mounted and wires are run, it'll look better.
    Sep 2006
    Ocala/Oviedo, FL
    33
    4,672
    12 Post(s)
    Ah, OK. What I don't like is how they stick up from the enclosure. I also don't like how bolts do that too without double laying the wood where they are. I guess that's why I prefer the radio shack terminals (not the cheapest ghetto ones but the banana plug ones).
    Video 1
    Video 2
    budget76's Avatar
    Mar 2007
    473
    1 Post(s)
    I agree, But I think with the amp mounted on top, they'll look alright. I'll mock it up and snap a pic. I was going to do bannana plugs, but the two I had the threads were shot, and I figured i'd try something different.
    Thanks for the input, always like to hear it.
    budget76's Avatar
    Mar 2007
    473
    1 Post(s)
    got pics with an amp sitting on the box like it would be. Didn't cut any wires to run between. It's only a mock-up. Wouldn't be if the amp wasn't blown
    I guess nobody likes it huh? 140 views and 2 people comment. I don't care if it's good or bad, but where's the feedback?
  9. #9
    Hecta G's Avatar
    Hecta G is offline Member
    Jan 2008
    ATL, GA
    71
    ummm, not much of an eye pleaser. Maybe if they were a little more stealth (lower profile and out of the way.
    What is their purpose that can't be done through other means?
    System: HeadUnit - Kenwood X591
    Front - MB Quart ESA 216
    Rear - Pyle PLG6C (yeah yeah, wife bought them)
    Sub - JBL GT102D
    Box - Dunno, still thinking and designing, will have pictures or CAD renderings.
    Amp - HiFonics BXi 606
  10. #10
    budget76's Avatar
    Mar 2007
    473
    1 Post(s)
    Quote Originally Posted by Hecta G View Post
    I was going to put them on the bottom of the back of the box, but if you saw my truck, you wouldn't be too worried about stealth. I've got no carpet to run my power, ground, RCA wires under, so there's a split loom visible through the whole truck.
    absolutely nothing, just thinking outside the box. I knew it wouldn't look as good as other methods, but used what I had around, and some spare time. I think plain bolts looks like ****, didn't have any bannana plug terminals with good threads, didn't have a terminal, and didn't want the wires thru the box like on my current box. Can't use 8ga with a 300 watt sub, and any smaller I don't think it would look good.
    thanks
  11. #11
    Hecta G's Avatar
    Jan 2008
    ATL, GA
    71
    oh, okay i understand a little bit better.
    You may want to walk through The Home Depot or Lowes in their fastener isle to see what's available. Maybe a stroll down the electrical isle will "spark" a couple of ideas...I know baaad punn.
    When i get stuck creatively I usually will separate myself from the project and brainstorm at either one of those.
    Sub - JBL GT102D
  12. #12
    budget76's Avatar
    Mar 2007
    473
    1 Post(s)
    Trust me, I know there's thousands of ways to set up the terminals. It wasn't that I was being cheap, impatient, ect. I had some time on my hands, an idea, and somthing that I thought would look decent. IMO, yes, it sticks out, but I think it looks okay and it does it's purpose. I agree they stick out a little, but i'm not building a show car.
    thanks
  13. #13
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Gonna have to cover that box in green or red felt, pool table style...
  14. #14
    Hecta G's Avatar
    Jan 2008
    ATL, GA
    71
    Well, dude, if that's what you want then you don't need us unless you were looking comments, suggestions, or snide remarks which is what I think you got.
    Good luck with the project, keep us updated!
    Sub - JBL GT102D
  15. #15
    Zakerid's Avatar
    Zakerid is offline Senior VIP Member
    Apr 2007
    At home
    387
    ehh.... i would have used brass bolts and something with a low profile on top.
