Results 1 to 14 of 14
Reload Thread: ported box.. which one
    jjoven1225's Avatar
    jjoven1225 is offline CarAudio.com Elite
    Nov 2002
    NJ
    35
    693
    i never made a ported box before, and im experimenting one for a friend.. which one would be better?? using a PVC pipe (exact port diameter + length) or building the port as a box.. like this http://www.subzoneusa.com/zv_series.htm
    do you tune the box? or the amp?
    also the sub requires 2 ports, and port length is 14.75" and port diameter is 3"
    also anyone have a good link "how to build ported box" or tuning them or whatever
    i've built sealed boxes before just never port and would like to learn, thanks for help
    Lexus IS300
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    You tune the box to the freq. you want.
    Round ports are good if you have the room and the manufacture gives you the diameter and length. Slot ports are good if you have a small box and need so much port area that a round port would be too long or you know what the port area of the box should be and the manufacture doesn't give you the demensions. It's just easier to figure w/o knowing the length and diameter, just the area.
    Since you have the length and diameter, I would go w/ the round ones...provided your box can handle the length. ((That's what I told her. )) Anyway, check out this and ignore the formula. It may help.http://jlaudio.com/tutorials/ports/index.html
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    jjoven1225's Avatar
    Nov 2002
    NJ
    35
    693
    i really dont want to go with the round port, cuz i think slot port looks better.. also since i have the length and the diameter, should i just match the length or of port, with the duck (slot) and same thing with the diameter, just get the area of the rectangle, i figure that's the same thing.. someone help..
    that formula was way too confusing..
    Lexus IS300
    dbirkes's Avatar
    dbirkes is offline Junior Member
    Apr 2003
    st. george, UT
    If i use this design of box could i just combine the two slots (the dotted line). or would it sound better to keep them seperated?
    dbirkes's Avatar
    Apr 2003
    st. george, UT
    so if each port was tuned to 40 and i combined them, it would still be 40?
    dbirkes's Avatar
    Apr 2003
    st. george, UT
    I just realized that was a STUPID question. how would you fiqure the length?
    dbirkes's Avatar
    Apr 2003
    st. george, UT
    in regards to my pic, would you measure down to where it splits and then add the length of the horizontal part?
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Originally posted by Jmac
    No ...
    jmac? Still alive and well?
    where've you been? Last I heard, your health failed you for a moment.. you ok now?
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
  9. #9
    dbirkes's Avatar
    Apr 2003
    st. george, UT
    so how would you recommend i build it?
  10. #10
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    man, are you lucky you got jmac to calculate the box for ya...
    jmac, just so you know, my box is solid man, your specs... a little too mcuh though, the sub blew its own gasket off, had to get new surrounds...but now it's fine... thanks for everything
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
  11. #11
    dbirkes's Avatar
    Apr 2003
    st. george, UT
    Would this be better?
  12. #12
    dbirkes's Avatar
    Apr 2003
    st. george, UT
    I'd have two ports. i have the formula from jl on how to do two ports
  13. #13
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    Two ports would be fine as long as you are calculating the TOTAL port area.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  14. #14
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    To find out the size of a slot port using round port numbers....
    you said you needed two ports being 3" X 14.75". This gives you a total port area of 277.89" (3 X 3.14 X 14.75 X 2 = 277.89) This is the area your slot port needs be. Take the opening of the slot L x W (let's just say 3" x 9" to get an opening of 27sq.") What X 27 would give you 277.89??...10.29". That is how long the port wound have to be.
    2006 Jeep Liberty
    *Vb = vol. in cu"
