Results 1 to 5 of 5
Reload Thread: Door Speaker Question
    wilsman00's Avatar
    wilsman00 is offline Member
    Jan 2008
    Rancho Santa Margarita, CA
    31
    Hello I am designing my door build and am running into an issue. This is my midbase:
    http://www.cdtaudio.com/pdf/ES-6_07.pdf
    Obviously it is better ported but I don't know how to make it work. I think I will be able to make enough room in the door to accommodate the 0.5 cu ft I will need. It would be a oddly shaped fiberglass enclosure with an MDF ring for the speaker to mount to. And I might be able to have enough room for the port but I don't understand how placement would work.
    If I make it like the diagram it would be in the door. And after all the sound deadening that would make it a ported box inside a sealed box. I would not be able to face the 11" from the door straight into the car either.
    Do they make ports that are curved so I could point the port out next to the mid?
    Or could I sound deaden the entire door (outer skin, inner skin) and just not close up the inner skin? So that way it would have access to free air?
    What do you guys think
    Thanks!
    Chris
    wilsman00's Avatar
    Jan 2008
    31
    Re: Door Speaker Question
    bumpadump
    wilsman00's Avatar
    Jan 2008
    31
    Someone has to have an opinion
    Perhaps I should post it in the Component forum.
    Anthony Collova's Avatar
    Anthony Collova is offline CarAudio.com Elite
    Jan 2005
    Scottsdale
    42
    1,415
    206 Post(s)
    This is how I sound deadend the doors in my old tacoma.
    The mids were all factory but it really made them come alive..
    http://www.cardomain.com/ride/2119519/2
    http://www.cardomain.com/ride/2119519/3
    ANT
    www.secondskinaudio.com
    AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
    wilsman00's Avatar
    Jan 2008
    31
    I'm already planning on using second skin. I have some products in my car already I just need some design help before I order materials.
    I know someone out there has though about the option of a ported box in a door. Common people
