Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Reload Thread: Work Log Continued: LMS5400+Sundown3000D
    Rawr-DQ's Avatar
    Rawr-DQ is offline !!!!Vote Third Party!!!!
    Dec 2004
    Fort Myers, FL Posts:____________31,337,666,999
    25
    2,882
    Old Thread: http://www.caraudio.com/forum/showth...=246233&page=1
    Currently messing with the tweeter pods untill I get some necessary tools/money/supplies.
    Using wood filler/glue molded the tweeter on the old factory sails.
    Test fit:
    Stretched fleece/a dress sock over the sail, used paper clips to pull the fleece in the hole.
    Applied resin:
    Quote Originally Posted by kickerassman View Post
    i was thinking some thing like this..... get a reall fine but strong sharp cable like them tension cables tie it around your neck and tie it to something..... then get some supper supper supper glue and glue your hands to your head.when the glue dries jump of the building with the cable cutting your head off and you would have your head glued to your hands ...... some one would see that and be like wtf omg that dude ripped his head off ... he mst have been pisssed!!!
    My Current Build Log: (16 8" Sundown subwoofers)
    http://www.caraudio.com/forum/showthread.php?t=367352
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Re: Work Log Continued: LMS5400+Sundown3000D
    Hardened:
    Started the finishing process:...
    After some sanding and dremel work:
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    After more sanding primer coats, and some carving so the tweeter can fit:
    Pretty much all that is left with those is primer sand the other one, and a few more coats on each till the holes are filled, then paint and wetsand smooth.
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Next up I will be smoothing out the back side sloping up to the sub ring then I will carpet the box.
    I will be turning the port into an amp rack and sealing the enclosure:
    Rsx_03's Avatar
    Rsx_03 is offline LoW aNd sLoW
    Jan 2006
    miami
    26
    343
    install coming along very nicely, congrats
    sick system too
    my suggestions:
    1st tweeter still needs some filling and smooting out
    glazzing puddy for that works the best for me
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Yeah they both need work, I just got my car back from the repair shop, and they stole my money, so I'll be a lil while before I can get the rest of the equipment.
    I don't think I mentioned I'm also switching from passive to active crossovers. And in the future considering another set of components.
    audioarsonal's Avatar
    audioarsonal is offline JaMarcus
    May 2007
    close to home...
    4,166
    Glazing putty is the way to go.You'll be forever trying to get the primer to fill all those holes.It drys pretty quick and can be sanded and primed in about 20 min.Then I use a primer sealer just to be safe.Lookin good though.
    Bought from:whiteram,Pyro_by_nature,AudioXtremes,Slab,IA2
    Sold to:annarbor84,ssackett,tapout383
    built for:skeptikal,Raid3r89
    SHADY SELLER:memphisman00
    Subs:4 Incriminator Audio Death Row 15's
    amps: Memphis 4K
    154.8@34hz
    Nov 2007
    Midland, MI
    314
    Looks like a crazy install so far man, keep it up.
  9. #9
    fwb_1234's Avatar
    fwb_1234 is offline CarAudio.com Elite
    Jan 2007
    Clemson, SC
    1,903
    Those tweeter pods look amazing.
    Refs: SeanDub, jblanford, 95BlackGA, Flipx99, BiaBia
  10. #10
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Needs some 2000 grit sanding and maybe a few more coats.
  11. #11
    KINGDELL91's Avatar
    KINGDELL91 is offline KING OF KINGS
    Jul 2007
    Detroit, MI
    2,459
    Looking good!!!!! you should do a vid
    CA REFS: themommyvan DECADO2, PATH2SPL, NEVERENUFFBASS, xhilr8n, jdc753, Racerx250, Zxcvtypo, hc3_cuz, wong05tsx, JK_AUDIO, Supergumby5000, Ken448,mojobass, craigzter, GMOORE, MitchZ, dumple, djman37,Thewes,Team MAF, Dragnix, and others
    ROE REFS: Stoker_41, xhilr8n, blackdragonx118
    Feed back Thread as a buyer trader:http://www.caraudio.com/forum/showth...ght=KINGDELL91
    Feed back Thread Seller:http://www.caraudio.com/forum/showth...20#post3761820
    BUILD LOG http://www.caraudio.com/forum/showthread.php?t=303112
    Quote Originally Posted by bones22 View Post
    this thread should get a lot of attention over the title.
    compared to the jackhammer that thing should be called a tack hammer
  12. #12
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    LOL, how about more pics with the tweets in them after the rest of the coats are done and dry?
  13. #13
    dragnix's Avatar
    dragnix is online now LXIX
    Dec 2006
    Socal cuz i'm So cool
    19,347
    21 Post(s)
    yes, more pix of the tweets. I could never be able to sand body filler smooth like that
    Got a pm regarding my sig
    Quote Originally Posted by audioholic
    please change it to something non-******. thankyou.
  14. #14
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    I decided to call this one done, just did 1 more coat on it and stuck the tweet in.
  15. #15
    Dtrickz's Avatar
    Dtrickz is offline 270 Customs
    Aug 2006
    greenville, ky
    498
    looks good man. you can use glaze to fill the pin holes or get some good primer. the primer we use at work, i can fill in grinding marks with anyways they look awesome man. nice work
    00 Escalade..FOR SALE
    headunit-pioneer avh-5700 w/ ipod adapt.
    Front stage- Fusion 6.5" comp. set
    Subs-2 18" Re SX's 16cubes..34hz
    amp-Fusion 2500
    batt-spl cell C-115
    aim-Diedrich5
    bought from:Team H&K,TeamPSI, wu501, FASTIMES, SPY, _JAY_
    A recent study shows that 92% of all teenagers converted to emo/punk etc. Put this in your sig if you're one of the 8% who stayed gangsta
