Results 1 to 2 of 2
Reload Thread: Box size for two woofers, why so big?
    td5turbo's Avatar
    td5turbo is offline Member
    Oct 2007
    a room
    34
    OK, so here are some somewhat noob questions but why does a box for two woofers have to be twice as large? I know it sounds like "well *******, twice the speaker, twice the volume" but when I think about it, doesnt the volume of air inside the enclosure just determine the resistance on the cone when it moves...like for a sealed box, a really small enclosure is going to limit the XMAX and a super large sealed box may make the woofer bottom out?
    I understand that some "dual" boxes are split, meaning they are like two seperate boxes joined together, and some are just a big empty space.
    It seems like a box that share the same box volume would "bottom" out or think they are in a very large enclosure.
    For example, say a sub is recomended to have 1.5cft sealed and 2.5cft vented per woofer...does that mean a "common volume" box of 5cft vented and 3cft sealed wouldwork perfect?
    Ir just seems like a box of 1.5cft or maybe slightly larger (like 2cft) would be perfect because each sub thinks its in that box without another woofer.
    Just trying to understand box design a little bit more.
    jmanpc's Avatar
    jmanpc is offline CA.com Nostalgist.
    Jan 2006
    Jacksonville, Fl
    25
    17,290
    Re: Box size for two woofers, why so big?
    www.bcae1.com
    read, young grasshoppah
    2007 Red Ford Focus ZX4 SE
    - Clarion DXZ955MC -
    - MB Quart RSD216 - 2 MB Quart RWE-354 in 4 cubic feet sealed -
    - MB Quart DSC4125 - Audiopipe AP1500.1D - Optima Blue Top -
    Team High Sexage
