Results 1 to 10 of 10
Reload Thread: Box for 94 Chevy regular cab
    NOTtooOLD's Avatar
    NOTtooOLD is offline Junior Member
    Apr 2003
    Memphis
    I am ditching my JBL 12 for an Audiobahn aw1006q. I am tired of sitting up on the steering wheel. I plan on purchasing an amp later on after I get my box built. I was gonna try to build a box that will place the sub facing down so I can obtain a narrower top section. The bottom will look something like this |___---___| with the center section about 6" off the floor where the sub will be mounted firing downward. I will have the full width of the truck to make the correct airspace.
    Does this sound like a good idea? Any drawbacks? Any ideas you guys (or girls) have would be greatly appreciated. BTW, I am not looking for competition sound or anything, just good clean bass.
    Also, any suggestions for an amp to drive this sub? also looking for some good component speaker for the front. not looking to spend a ton of money.
    Thanks.
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    34
    16,641
    20
    1 Post(s)
    76 Post(s)
    I was actually thinking about doing that with some L5's, but i just designed a box that would position the subs behind the passenger. Do you have bucket seats? If not, then the down-firing sub seems like it would work, but i don't know if the bass would be muffled at all because it is reflecting off of the floor.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    NOTtooOLD's Avatar
    Apr 2003
    Memphis
    No buckets, just a plain ol bench seat
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    34
    16,641
    20
    1 Post(s)
    76 Post(s)
    You could always get some buckets!
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    NOTtooOLD's Avatar
    Apr 2003
    Memphis
    LOL, yeah, you are right. But that would be more money :P I plan to get a new truck with extended cab in the next year so I really hate to put more in this one than I have too
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    Im was the same boat that u are in with limited space(1995 chevy s-10 standard cab). I had just bought two AW1005Q's (audiobahn ROCKS) and am having a tad bit of trouble fitting them BOTH in there in something other than a sealed box. I don't know about u but I am willing to sacrifice ALOT of space to get what I want. Im a small guy so I can pull my seat all the way up and still be comfortable. Basically what i did was set up my subs shooting into the box( gut's out ) along with alot of angle that allow it to just barely fit back there. Yes it is cramped in my truck. If u wanted i could show u my 3d design of the box. As for the Amp to run it I would personnaly buy the Audiobahn 18001DT or the 8001DT I have the 18001DT along with a 6601Q( you can NEVER have too much power). But thats just me I don't settle for anything less than audiobahn.Or u could buy the new A5100T for everything. I really haven't looked at any new components but I had all my stocks replaced with kenwoods and they did good until i tried to push 75w continuous through them. They are rated at 50w and 40w rms.
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    34
    16,641
    20
    1 Post(s)
    76 Post(s)
    Yeah, the reason i can't fit a big box that i want is because i have a standard cab, but i am 6'. So i need as much room as humanly possible. That's why i'm gonna put all the subs on the passenger side! I'll figure it out eventually. Right now I'm just doing all of my dampening that i can without tearing the seats out.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    Oct 2002
    Fort Meade, MD
    35
    873
    Well i hate to say it but your out of luck. There is no way that u can fit those things in the standard cab. i have the 1005q's and they are as a slightly smaller than the 1006q's and i have both the seats ALL the way foward and they just barely fit. I have thought of every other possible configuration of those speakers but there is no way to fit them back there without having the seat all the way foward (or removing the seat all together). Good luck.
  9. #9
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    34
    16,641
    20
    1 Post(s)
    76 Post(s)
    Well, he can still do the down-firing technique. It'll probably fit, but i don't know how it's gonna sound.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
  10. #10
    NOTtooOLD's Avatar
    Apr 2003
    Memphis
    Well I should get the sub tomorrow. If so I am gonna start working on the box this weekend. Will try to post a pic next week of the finished product and let you all know how it sounds. If it doesnt sound good, I'll just try something else
