Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 69
Reload Thread: 2008 WRX Worklog *pics*
    DarkFox's Avatar
    DarkFox is offline CarAudio.com Elite
    Apr 2006
    Old Lyme, CT
    29
    634
    Well I just finished the 98 Mustang work log, and then immediately got a new vehicle... lol bye bye Mustang.
    So thus starts the WRX work log. This is gonna be over the next few weeks, so no extraordinary progress between pics. But here you go:
    P/S, this is also gonna be my daily driven work vehicle, so nothing crazy is going to happen in here. No walls or crazy fiberglass, just trying for a good clean system, on a car with not a lot of info yet.
    The Car:
    The Dash:
    Still trying to figure if I want to use the factory radio and a fancy hi/low converter (to maintain the 6 disk changer and save some money, or install a nice nav unit.
    OK, for the rear speakers, take out a screw in the handle area where you pull the door shut, pop that piece straight up evenly (not up and out like previous model year, broke my first tab on first piece ) This reveals two more screws, remove them. Then inside the handle to open the door there is one screw, remove it. In the corner there is a piece of black plastic trim (little triangle on the door.) Pull it straight out and twist slightly to the front as it comes out. Then starting at the bottom, pull the door straight out to pop out the little plastic compression fasteners. At the top of the doors, there is no fasteners, when it feels like just the top 1/4 is still being held in, slide the door straight up along the path of the window and pull the panel off.
    The factory speakers are retained by a plastic shroud and three screws, remove the whole thing by taking out the three screws. In the rear, 6 1/2s fit perfect in the door, and the window doesn't get in the way at all, so just drill holes in the door for the screws and directly mount the speakers.
    FRONT SPEAKERS on the other hand are a different story. The Infinities I put in the front are not that deep, and still hit the glass. Also, the factory speaker holders position the speaker too close to the doors, and the tweeters push against the grill in the door, so I made my own adapters, though I think if you buy the ones for last year, they probably still fit. Since this actually required some handy-work, here are the quick adapters I made.
    If you notice the two screws just to the left of the wood, they hold in the crossovers. I installed all 4 crossovers in the same fashion in each door.
    In the front the speaker wire is outside the door, so I had to drill a small hole to run the speaker wire through to the crossover, and secured the wire to the bracket. In the rear its all internal, and no where near moving parts, so no worries.
    SPECIAL THANKS!!!! To Manny at T-Rex Car Audio. Even when I was offering to pay for it, he encurged me to "just go for it man" and though I broke one tab, still not going to hold it against him ;-) Great guy and thanks for the help.
    Quote Originally Posted by heyman421
    If SPL is your main objective, get 10's or 12's instead.
    Current System
    Car: 2008 WRX
    HU: Pioneer AVIC-D3
    Fronts: Tweeters up top
    Infinity 2ohm 3-ways in the doors
    Rears: Infinity 2ohm 3-ways in the doors
    Mid/High amp: HiFonics Zeus ZXi 4406 @ 110 X 4 rms
    Subs: 2x 12" Kicker L7 D4s
    Sub Amp: HiFonics Brutus BXi 2006D @ 1ohm (2KW RMS)
    98 Mustang Work Log (pics)
    08 WRX Work Log(Pics)
    DarkFox's Avatar
    Apr 2006
    Old Lyme, CT
    29
    634
    Re: 2008 WRX Worklog *pics*
    Well I usually turn this into a paint layout so it all looks neat, but today I really didn't care. you get the idea here, its just not as pretty. All the wood is cut, should have some pics of the build later today or tomorrow.
    Current System
    Car: 2008 WRX
    HU: Pioneer AVIC-D3
    Dec 2006
    Oak Hills, CALI
    1,681
    im still wondering why they changed that last body style, the last one before this was sick
    TEAM DEAFSQUAD
    TEAM POWERMASTER
    TEAM SPLZ
    bumpin buick's Avatar
    bumpin buick is offline Science is everything
    Jul 2007
    Appleton, Wisconsin
    11,023
    wanted to stay one step ahead of the evo maybe?
    http://www.caraudio.com/forums/buyer-seller-feedback/305521-official-bumpin-buick-feedback-thread.html
    KidThump's Avatar
    KidThump is offline V.I.P
    Oct 2006
    Georgia
    1,845
    What subs are you using? L7s that was in the mustang?
    01 Jeep Grand Cherokee Laredo
    JVC KD-S26- AP 100.2-AP 1500d
    DarkFox's Avatar
    Apr 2006
    Old Lyme, CT
    29
    634
    yeah, the L7s from the stang. I know I know.. its a bit small and not alot of port area, but still need useable space in the back. if it sounds like poop, easy enough to cutout a peice big enough to cover port and turn this into a 3.6ish sealed enclosure
    Current System
    Car: 2008 WRX
    HU: Pioneer AVIC-D3
    Dec 2006
    Oak Hills, CALI
    1,681
    yea but the evo looks 20 times better imo.. but there not bad looking just dunno but the wagon look
    TEAM DEAFSQUAD
    TEAM POWERMASTER
    TEAM SPLZ
    KidThump's Avatar
    Oct 2006
    Georgia
    1,845
    Quote Originally Posted by DarkFox View Post
    naw it should be fine......Maybe you should get Cvxs they can be in smaller boxes and IMO have the same spl with better sq
  9. #9
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    It's a hatchback, and they look **** as **** on the Impreza's.
  10. #10
    azbass's Avatar
    azbass is offline the salty ca.com mod
    Sep 2004
    Long Beach, CA
    34,922
    Quote Originally Posted by SplChoice- View Post
    it looks more for a hatchback to me, like the car in your sig..
  11. #11
    DarkFox's Avatar
    Apr 2006
    Old Lyme, CT
    29
    634
    its called a 5 door w/hatch so as far as my insurance is concerned (Geico) its a hatchback
    anyway, some more stuff thats going in it.
    *Note: I love sonic electronix*
    Current System
    Car: 2008 WRX
    HU: Pioneer AVIC-D3
  12. #12
    Dec 2006
    Oak Hills, CALI
    1,681
    yeah but its like 4 doors and kinda long i know its a hatch lmao i just said it looks more like the legacy wagon thing
    TEAM DEAFSQUAD
    TEAM POWERMASTER
    TEAM SPLZ
  13. #13
    azbass's Avatar
    Sep 2004
    Long Beach, CA
    34,922
    my hatchback has 4/5 doors
  14. #14
    treasony's Avatar
    treasony is offline 89 Super Coupe
    Nov 2007
    Evansville, IN
    213
    do you have any pics of the mustang install? if so plz post, i just did an install in mine and want to see what others have did. Im working on the front stage now.
  15. #15
    DarkFox's Avatar
    Apr 2006
    Old Lyme, CT
    29
    634
    Current System
    Car: 2008 WRX
    HU: Pioneer AVIC-D3
