Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: 2000 Ford Ranger build log
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    36
    368
    Alright, long time since I've done any stereo work, and I figured this will take a few weekends (at least!), and since I <3 reading build logs, as I'm sure most of yall do, I figured I'd go for it.
    Clarion dxz835mp
    crystal csc643s 3 way components
    2 ed 7kv2's
    Jl 300/4
    jl 500/1
    Kicker 0/1 kit.
    A ton of deadener (whenever I order it)
    So I've got most of the equipment, just waiting to order the deadener to install everything. However, in the meantime I can do SOME of the work.
    This can also be a decent how to on molding plastic panels, since I cant stand cutting into factory stuff without a replacement.
    Okay, lets start with some blurry pics of my gear and my sloppy work area, oh and my toe.
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Re: 2000 Ford Ranger build log
    Okay, now that we got that out of the way, lets talk about fiberglassing.
    Get a cup like this, plastic, with ounces listed for measurement. They have them at home depot, harbor freight, etc.
    One of my favorite things ever, you squeeze the bottom and MEKP fills the container at the top. Measured in CCs. My MEKP is red, I got it form Select Products a while back, along with the mekp dispenser.
    This bit of chicken scratch is my reminder. I use a ratio of ~4% hardener to resin. I personally like to use smaller, hotter batches, especially when I'm doing small scale work. Using 2% gives ~20 minutes of work time, 4% is closer to 10.
    When I'm doing big jobs I use closer to 2% since I dont want to have the cup of resin solidify on me. It's just personal preference, if you are not that good with 'glass, go for a longer work time. If you are doing a lot of layers, do a longer work time and then you can layer a lot with one batch of resin. However, for this project, I dont need more than 2 layers of matte, and I didnt want to sit around waiting for this stuff to dry all day.
    *WARNING* Making a batch too hot (too much MEKP will cause you all sorts of trouble. The plastic bowls can melt, the resin can crack, and the project can be ruined rather quickly.
    Other material not pictured: Paint brushes, gloves (LOTS) resin, matte )chop and weave. harbor freight is awesome for gloves and brushes.
    Okay, lets get glassing! Not too many action shots, since I was kinda busy.
    Proper safety equipment! I found the chem lab goggles dont fog up as much as other glasses.
    Wet 'glass.
    Dried.
    'Glass does not stick to plastic, so it will pop right off.
    Some minor trimming, looks pretty good!
    No plastic was harmed in the making of this thread.
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Okay, a little tip. When you use up a batch, there will always be some left. Take your brush and put it back in the plastic cup.
    Because, when you pull it out, it will pull out all the resin and crap in the cup. It also gives you cool little bits of artwork.
    Clean cup! Saves you the trouble of pulling out dried resin, or having it break off the sides and end up in the wet stuff, then on your project.
    Doh! This cup was showing it's age. A little too hot a batch weakened this spot, and when I tried to pull the brush/resin out, it broke the plastic. Reason number 234234 why you buy extra cups.
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Stock Kick panels
    My glass replicas. Pretty close right!
    Sloppy work area! I didnt want to ruin a piece of wood, so an old rubbermaid lid works. 'Glass doesn't stick to it either.
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Okay, onto the rest of the project. Lets make some baffles.
    Yeah, gorilla glue and titebond are cool, but this stuff is my favorite.
    CA ( cyanoacrylate) Glue, superglue, whatever. Pick it up at your local hobby shop.
    Get this stuff too. CA accelerant. Turns 5 second glue to 2 second glue. Really helps when gluing supports or just holding a panel in place. I've built boxes with this stuff, and it holds great. Eliminates all the drying time.
    Okay, some jigsawed baffles.
    Where the mid and tweeter are going
    My router table
    Rounded the edges. This does two things: aesthetic improvement when glassed, and it gives the 'glass more surface area to stick to.
    ARRgh, wouldnt be my project without something like this happening. Double check the bit height before you start.
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Fleece, glued around the panel, in the baffle, etc etc
    Lawnmower doubles as a drying rack
    Reinforcing
    I like to lay the weave matte last, since it gives a much smoother finish. Requires far less sanding at the end.
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Missing a few pictures, slap on some body filler, sand, repeat.
    This was about a day and a half. I have a bunch more body filler to throw on, lots of sanding, then painting!
    bryce-man's Avatar
    bryce-man is offline CarAudio.com Elite
    Feb 2007
    beach cities CA
    1,180
    subscribed for another ranger owner
    anddd im doing basicly the same without the kicks this winter break
    Refs
    Bought from
    CA --orioles26,97cavy(ups=crap),mike dressure x2,rtillaree,gordos420,ultimate157,pioneerpimp,Pim pdaddyq,Anonymous User,thatkidbob,amartin_72,snoopysnooper,hemi=22s, dvrmstrng,revots,nathan from EA,Adrianos,JRsmoothie,flexxissues
    Ranger-Forums.com --Ranger1
    Ebay --johnbryan67,knu, and countless stores
    Sold to
    sanmaim,SWEET06CAMRY,mud
  9. #9
    eric12421's Avatar
    eric12421 is offline Senior VIP Member
    Aug 2005
    RI
    30
    242
    so youre pretty **** good with that fiberglass...im impressed!
    1999 Ford Ranger 2.3l 5 speed Standard Cab
    Alpine CDA-9815
    Boston Pro 60's
    Ascendant Audio Arsenal 10"
    1.2 cubic feet @33 hertz
    Refs: dB Dom, mike11202, sundownz, jblayz1, Skip01, andreilopez, XaznKewLguyX, jfa1177, HawaiianBassHed, shiftmx6, j0ne, JiggaD369, criswrld
  10. #10
    skadude016's Avatar
    skadude016 is offline CarAudio.com Veteran
    Feb 2003
    Canton, GA
    32
    7,317
    13
    2 Post(s)
    looking forward to see the end product
    HU:Kenwood Excelon KDC-889
    Speakers: CDT 61A's with rainbow x-overs
    Front amp: Autotek MM100.4
    Sub amp: (2) Audiopipe 1500's
    Subwoofers: (4) 15" Crunch GPV
    Box: 16 cubes tuned to 28hz (removable port)
    Extra Batt: C&D 139AH
    151.xx sealed up 154.xx in the kick
  11. #11
    RumbleNTheTrunk's Avatar
    RumbleNTheTrunk is offline CarAudio.com Elite
    Jun 2005
    Liberty, TX
    28
    1,922
    good thread...you gave good advice...along the way....this forum enjoys that. Way to go..looking nice.
    2009 Pontiac G8 GT
    SLP Loud Mouth Axleback -- Installed
    Vararam CAI w/ HSRK -- On the way
    ARH 1 7/8 Headers Catted -- Very soon
    Feedback here
    CLICK HERE
  12. #12
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Quote Originally Posted by skadude016 View Post
    So am I! I'm anxious to get these things done and move on. Thanks for all the compliments, if there are any questions, just ask!
  13. #13
    Rage00's Avatar
    Rage00 is offline Member
    Oct 2005
    Grand Rapids, MI
    39
    123
    subscribed........................................ .....
    What did you say?
    yahoo id: peoples0079
  14. #14
    audiobahnuser18's Avatar
    audiobahnuser18 is offline CarAudio.com Veteran
    Nov 2005
    Mi
    30
    10,081
    15
    Very nice work man look forward to seeing the end product. x2 also gave good advice along the way. keep it up man.
    Refs
    Bigjon47 , JohnnyBussa , Mike Dressure , BTLking , Myjaja , Tapout , prowler573 , mommyvan , R-sosa , Audio Master , 95BlackGA , wu501 , Nismos14 , HawaiianBassHed , ECS23 , Bagged96Chevy, Donpisto , the other mike kmanian bumpin buick dumple wrench , guy , blazinb2000 , teen , phl1ser , Loud3 , Plyer3 , LazyRider , Jk32sho , MacQ32
    TreZ0r Is a lieing piece of sh*t scum bag SCAMMER!!!!
    REBUILDING IT ALL
    REFS:http://www.caraudio.com/forum/showthread.php?t=353034
  15. #15
    the727kid's Avatar
    the727kid is offline CarAudio.com Veteran
    Jul 2006
    St. Pete, FL
    3,263
    127 Post(s)
    Shoulda put all these pics on TR... looks good tho
    Alarm: Viper 5902
    HU: Stock
    Front Stage:
    Tweeters: Image Dynamics CD1-Pro Mini Horns
    Mids: Sundown Neo Pro 8"
    Subs: (2) 15" Dayton HF ran IB
    Amps: (2) Kicker IX 500.4 (1) Kicker IX 1000.1
    Processor: JBL MS-8
