Results 1 to 3 of 3
Reload Thread: box demensions
    Jan 2003
    Cullman, AL
    28
    120
    box demensions
    If I built a box 36x15x15, how many cubes would that be (internal)would that be around 4 cubes. If not, how would I figure up 4 cubes.
    HLLRZR13's Avatar
    HLLRZR13 is offline Member
    Jan 2003
    Grand Island, NE
    81
    The way to calculate air space is WxHxD divided by 1728. If you want to cheat you go to www.rockfordfosgate.com they have a technical department that has a volume calculator where you just type in your measurements.
    Eclipse CD5442 deck
    SAVV 5.6" Monitor flushed into dash
    SAVV 7' flip down monitor
    JL Audio 500/1 for subs
    JL Audio 300/2 for components
    JL Audio XR525CX components
    2 JL Audio 10w3v2 subs under backseat, Audio Control EQX
    Sony Playstation 2, 2 Optima deep cycles, and too many things under the hood to list.
    98 GMC Z-71 Extended Cab Vortec 5.7
    Apr 2002
    Idaho Falls
    36
    1,134
    If you gave us outside dimensions and it's made from 3/4 stock the internal air space would be 3.64 ft^3 before displacement!
    '99 Ram Sport Quad cab
    Alpine 7897
    Rainbow 6.5 comp. set
    180 amp Iraqqi alt
    Optima yellow top
