Results 1 to 4 of 4
Reload Thread: need box build help in west tn
    scorpion055's Avatar
    scorpion055 is offline Member
    Jun 2007
    milledgeville, tn
    130
    looking to build a box for my 2 kicker cvr 12's. will be in the back of an extended cab ranger.
    ive never built a box before and could use some guidance along the way.
    found some prefab boxes online that i like the design of here: http://www.hifisoundconnection.com/S...48233250239240
    utilizes the hump in the extended portion of the cab. subs downfiring.
    i want mine ported though. ~4 cubes at 32-34hz. i guess port down as well.
    basically i found the design and liked it a lot. but want it ported. so anybody in west tn around the jackson area willing to help me build this in a month or so?
    Apr 2007
    Lehigh Acres, FL
    26
    117
    Re: need box build help in west tn
    i live in jackson bro. if you have the tools i can come up with a design and can help you build the enclosure.
    Apr 2007
    Lehigh Acres, FL
    26
    117
    and just to let you know bro, to do 4 cubes at 33hz is going to be a little bigger than that box there. get some measurements of your truck and post them here and i can try and make you up a box.
    Jun 2007
    milledgeville, tn
    130
    yeah i knew it was gonna be bigger. i just like the overall design. it probably wont be for 3-4 weeks before i do it, but ill get some measurements in the meantime.
