Results 1 to 10 of 10
Reload Thread: Door panel design help needed
    00RedRT's Avatar
    00RedRT is offline Sidewinder
    Oct 2007
    Atlanta, GA
    89
    OK, I'll start with equipment I'm going to be using. The Dynaudio 362 setup. The tweets will be on the A-pillars, the dome mids will be in the kickpanels, and the 8" midbass will be in the bottom front of the doors.
    The tweets and domes I have no problem with fabbing up those areas. But the midbass I'm having problems with. I could easily mount a baffle to the metal of the door and install the factory door panel back over the 8" midbass for a clean factory look. But the factory grille is angled towards the floor ie not optimum for SQ.
    Also the factory tweeter grille is located on the door panel so I'd like that to go away as well. The door panel is all one piece molded plastic, so I don't even have the benefit of taking apart the lower half or anything. So I guess I'm wondering if I should glass over the whole door? Glass just a speaker pod area for the 8"? Any other design ideas?
    Take a look at the picture below as you will see the door panel and the challenge I have before me....
    Thanks in advance for any help/design ideas!
    Darren Alcorn
    2000 Dodge Dakota "Sidewinder" R/T
    SQ Dakota install completed!
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    Re: Door panel design help needed
    Nice car. I wouldn't touch it...
    Flipx99's Avatar
    Flipx99 is offline Violator of Terms
    Aug 2005
    Building 100
    23,978
    2 Post(s)
    I go two way so you wouldn't have to modify anything.
    I think there is a 162GT series that would drop right in.
    Black cat, white cat...all that matters is that it catches mice. -Deng Xiaoing
    I do homework for money. I specialize in finance. PM me for estimates.
    If someone uses me as a reference, please contact me first.
    dB-SPL's Avatar
    dB-SPL is offline CarAudio.com Elite
    Aug 2007
    Canandaigua, NY
    837
    Just get a 5.25 or 6.5 2-way comp set. After all, it's the woofer that's aiming toward the floor, you get to choose where the tweeter goes..
    -Bill-
    '11 Jeep Patriot
    Head Unit - Pioneer AVH-P3200DVD
    Front - Infinity Kappa's
    Front Amp - Soundstream 200.2
    Subs - 2 Obsidian 15's in 5.5 cubes @ 28Hz
    Sub Amp - Skar 1500
    Stock Electrical
    142.8 @ 41Hz
    Pimpdaddyq's Avatar
    Pimpdaddyq is offline Owner: Quicks Car Audio
    Apr 2005
    Clinton Iowa
    25
    2,496
    Yea i would do what you already plan on doing, but just drop that mid in and don't worry about it facing more towards the floor..
    I mean yea SQ won't be as good as you could make it, but unless you are 110% confident on what your doing, and KNOW how to do it, I would leave it and keep the clean look without messing something up..
    Either way, nice truck, good luck with the install man, post pics!
    Andrew
    Refs: 02Corvette, PsychoTheRapist, Quez82, Fattony911, Megalomaniac, PatFitz9, Twistid, Robertspangler, SPL140.2, hazardous0388, scoob8000, WOT, Rashadd, Tricked - CS.org: TommyTheCat, HawaiianBassHed, MLGreen, Jmanpc..
    Owner: Quicks Car Audio and Detailing in Clinton Iowa
    -- 1995 Honda Civic -- -BlackedOut-
    Black Car, Tinted, Black 17s, 12K HIDs, Black Halo Projector Headlights, and Black Tails...
    Pioneer DEH-P6000UB
    2 Soundstream PCA2000D, 2 Older 15" "Fi Reconed" Immortals 7.5ft^3 at 30hz (SOLD)
    Cheap Kenwood 4ch
    6.5 RSD Components in my Doors
    HO Alt, 1/0 Knu Collossus Wiring, Optima Red In Back
    Xbox Live Gamertag: MistaAPQ
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    28
    15,426
    21
    picture no worky.
    99dango's Avatar
    99dango is offline Member
    Aug 2007
    Houston
    112
    in my durango i pulled the tweeter grill out, mad the hole big enough to flush mount my rsd6.5 component tweeters and called it a day...sounds pretty good actually.
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    28
    15,426
    21
    you could take the door panel off and look at the back side of the grille. sometimes they use melt rivets to keep them in place, if its moulded into the panel, your only bet is to cut it off.
    prolly just flush the tweet in place of the grill, cut a hole and flush a dome in that empty area below it, and then cut a hole in the panel and build some .3cube pods at the base of the door and paint to match the cool red **** on the buttons.
    least thats what i would do
  9. #9
    audiobahnuser18's Avatar
    audiobahnuser18 is offline CarAudio.com Veteran
    Nov 2005
    Mi
    25
    10,082
    15
    Very nice interior by the way though man very nice.
    Refs
    Bigjon47 , JohnnyBussa , Mike Dressure , BTLking , Myjaja , Tapout , prowler573 , mommyvan , R-sosa , Audio Master , 95BlackGA , wu501 , Nismos14 , HawaiianBassHed , ECS23 , Bagged96Chevy, Donpisto , the other mike kmanian bumpin buick dumple wrench , guy , blazinb2000 , teen , phl1ser , Loud3 , Plyer3 , LazyRider , Jk32sho , MacQ32
    TreZ0r Is a lieing piece of sh*t scum bag SCAMMER!!!!
    REBUILDING IT ALL
    REFS:http://www.caraudio.com/forum/showthread.php?t=353034
  10. #10
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    28
    15,426
    21
    this is a crappy mock up, but yea.
    its 10 minutes in PS.
