Results 1 to 10 of 10
Reload Thread: Where can I buy ports?
    FiendAZ's Avatar
    FiendAZ is offline Member
    Dec 2002
    Phoenix
    32
    Where can I buy ports for my subs?
    Thanks.
    Apr 2002
    Idaho Falls
    41
    1,134
    are you looking for aeroports or what?If not You can build your own out of mdf (or any other wood) if you want a slotted port! If your looking for round ports pvc pipe works great
    '99 Ram Sport Quad cab
    Alpine 7897
    Rainbow 6.5 comp. set
    180 amp Iraqqi alt
    Optima yellow top
    FiendAZ's Avatar
    Dec 2002
    Phoenix
    32
    Oh really? What diameters does PVC pipe come in?
    Apr 2002
    Idaho Falls
    41
    1,134
    Any size you could imagine!!! From 1/2 up to at least 12in that I know of
    Alpine 7897
    180 amp Iraqqi alt
    Optima yellow top
    FiendAZ's Avatar
    Dec 2002
    Phoenix
    32
    Where can you buy the port flares?
    FiendAZ's Avatar
    Dec 2002
    Phoenix
    32
    If I can keep my vent mach low enough, then do I even need to buy flares?
    Savant's Avatar
    Savant is offline Duke of DOH!
    Dec 2002
    Colorado Springs, CO
    48
    1,347
    I don't think you actually need the flares, perse'.. You can always smooth the edges (that will help some) if you need to.. and I'm pretty sure it has mostly to do with the mach .. meaning that yes, if you keep the mach low enough you shouldn't need flared or smooth edges on the port..
    (1) Alpine CDA 7892 HU ($214)
    (2) 12" Pioneer Premier 1241DVCs in sealed MDF box (gonna glass them eventually) ($69 each)
    ->removing.. ->(2) 10" Pioneer Premier 1041DVC's in sealed MDF box (gonna glass them eventually) ($59 each)
    (2) Lanzar Vibe248 1200 watt 2 chnl amps ($119 each)
    It's bump'n GOOD!
    You can lead a horse to water but you can't make a moron understand...
    FiendAZ's Avatar
    Dec 2002
    Phoenix
    32
    Is there any problem with using 2 ports per sub chamber?
  9. #9
    Savant's Avatar
    Dec 2002
    48
    1,347
    You 'should' be able to have as many as you like.. just have to have them the right sizes for the tuning freq.. And, if they are too small, you might still get mach noise even if you have a lot of ports..
    But, you should be able to have any number of ports per chamber as long as they are proper size (length/diameter)..
    EDIT: Look here for WinISD.. an app that will help you design the box.. the 'alpha' of pro doesn't show box dimensions though.. but..
    http://www.linearteam.dk/
    Good luck..
    It's bump'n GOOD!
  10. #10
    FiendAZ's Avatar
    Dec 2002
    Phoenix
    32
    OK......I have everything working, the holes cut out and my subs back in. I must say that vented sounds MUCH better than sealed. However, I think there may be a problem. I did not know how to figure in the port length and volume of the port etc.. into the equation. WinISD did it for me, however the PVC pipe was a diameter of 2.4 inches, with a flow area of 2 inches. Now, this factors into the equation differently in WinISD. If I have a bigger port diameter (which I calculated it for - I now have 2 2.4 inch ports that are 8.5 inches long. I fear that this may be too long - hence tuning my box lower than I wanted to, at about 32.something hertz, when I want it around 35.
    1) With most rap music, what is the lowest note that is hit? Is there really any sound below 30 hertz that is conventionally played?
    2) Should I start lobbing off 1 inch chunks of PVC pipe?
    Now, this is where I have a new question. What if I cut each indivicual port to a different length - like if WinISD wants it to be 6.5 inches long, and I made 1 port 7 inches long, and the other 6 inches long for tuning frequencies of 33 and 35 hertz, respectively. What effect would this have on the sound quality? Has anyone ever tried this before?
