Results 1 to 5 of 5
Reload Thread: Guidance/Tips on Fiberglassing this box (pic).
    nrgy's Avatar
    nrgy is offline Member
    Nov 2002
    USA
    100
    I would like to make a subwoofer enclosure for the rear shelf of my car. I came across this picture on the web, and I want to make my enclosure nearly identical to this one.
    I already decided that I will probably use some type of styrofoam to mold the curved edges, but what steps would you guys use to build this box? Also, would you reinforce any areas with wood, such as the middle?
    I'm thinking I would probably fiberglass the top and bottom, slide out the mold from the front or back, and then fiberglass the front and back. By the way, the 8" sub would mount in either the left of right side, facing up.
    The dimensions would be apprx. 41"L x 9"D x 4"H. I know 4" doesn't leave much for mounting depth, actually the subs mounting depth is exactly 4", hopefully this will be ok.
    I would be covering this in black vinly or leather once completed. Any tips or suggestions? This will be my first fiberglassing project. Would this be too difficult for a beginner? I've built custom amp racks out of wood, and wood enclosures so I consider myself somewhat of a DIY and handy man. Thanks in advance.
    Now Playing:
    JBL P80.4
    Boston Acoustics Pro Series 6.53 Components
    Tsunami Silencer Sound Deadning
    Waiting for Installation:
    Boston Acoustics 8.5LF Pro Series Subwoofer
    Coming Soon:
    JBL 300.1
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Let's see here...I would use some form of biaxial woven mat such as kyntex. It won't take but a couple of layers and will be stronger than you could ever need. As for stiffening. Just lay some rope to make some ribs. Simply resin the rope in between the layers of mat. if you plan on the any large panel being flat I would make it out of MDF. it's just easier. Believe me .
    As for a mold. There are a couple of ways to accomplish what your after. You could use the floral foam. Or you could make a wooden box square that's about an inch larger than your enclosure. Grease the inside of the box with some form of lubricant like vaseline. Then fill the box with great stuff foam insulation (the crap in the can that expands) Then once dry. Pop the block of insulation out of the box. Then carve your mold. Once you have your mold the shape you desire. Start glassing.
    5 % equipment
    90 % install
    5% beer
    Savant's Avatar
    Savant is offline Duke of DOH!
    Dec 2002
    Colorado Springs, CO
    48
    1,347
    I'm not sure you need to have any kind of 'mold' from foam.. I mean, it looks like you have 2 'flat' surfaces (they are the long ones that are flat on the ground and have the curves in them).. if you cut some MDF that's flat on the one side and has the curves to the other side (you would have 2, one for each 'face'), you should just be able to pull the glass tight over that curve while building it up.. I would think a staple or two to hold it tight while the first layer dried would be fine.. and that helps give you maximum volume.. *shrug*
    That's just what it looks like to me...
    (1) Alpine CDA 7892 HU ($214)
    (2) 12" Pioneer Premier 1241DVCs in sealed MDF box (gonna glass them eventually) ($69 each)
    ->removing.. ->(2) 10" Pioneer Premier 1041DVC's in sealed MDF box (gonna glass them eventually) ($59 each)
    (2) Lanzar Vibe248 1200 watt 2 chnl amps ($119 each)
    It's bump'n GOOD!
    You can lead a horse to water but you can't make a moron understand...
    nrgy's Avatar
    Nov 2002
    USA
    100
    Alright, thanks for the suggestions! I will use some of the techniques you suggested. I plan on using carbon fiber just to see how it looks when I'm finished. But how would you get a nice smooth, shiny carbon fiber finish if you have to layer and then sand smooth? Do you have to polish it or something? And does the nature of the carbon fiber weaves mask any layering?
    Also, since it is fibers, when you sand it won't some of the fibers start to fray? Hopefully this question makes sense.
    Now Playing:
    JBL P80.4
    Coming Soon:
    JBL 300.1
    ASDF12345's Avatar
    ASDF12345 is offline Senior VIP Member
    Nov 2002
    us
    260
    hey your in luck..............you dont need fiberglass to build that box. the top piece thats corved can be made by plunge cuting mdf. youll need a plunge router. say your using 3/4 inch mdf, the the plung router to a little less then 3/4. make cuts in parell lines ever 1/4 inch and the mdf will bend. so make the cuts, then fill the grooves with bondo. set the mdf aside and let the bondo dry in the shape you want the panel. to make the sides just trace the top panel and cut side pieces. anymore help, pm me.
