Results 1 to 13 of 13
Reload Thread: 15" Kicker L7 box help?!?
    superwhite06's Avatar
    superwhite06 is offline Junior Member
    Sep 2007
    Beacon, New York, United States
    Hey guys I'm a new comer to the car audio forums but not to car Audio in general.
    I have a question for the car audio gurus!
    I am wanting to put a 15" Kicker L7 into the trunk of my 2006 Scion tC. (I know I would have to completely remove the spare tire and anything else that will get in the way.) Anyways, I was looking on the Kicker website and the min. rec. sealed box volume is 1.5 Cu. FT. and the ported is 3.0 Cu. Ft.. I am going to get the box a little above the minimum recommended.
    Which is a better box design for a spare tire setup?? and how would i go about building a ported box in the spare tire??
    I pretty much have a design for the box if it is sealed, which is just a square with the dimensions of 22x22x9 which would give me 1.94 Cu. Ft. of space.
    Is that plenty for that sub?? or do I need more?? The max dimensions I could go would probably be 23x22x9.5.
    Thanks in advance for the help.
    Greg
    Stem's Avatar
    Stem is offline n00b Poster
    Oct 2005
    Kauai, HI
    24
    371
    Re: 15" Kicker L7 box help?!?
    i'd give a 15 L7 3.5-4 cu ft ported, otherwise it might get peaky. you wont have enough space if those are your max dimensions. and unless you were planning on fiberglassing the spare tire wheel well im not sure where ur going with this, thats just my $.02
    Sep 2007
    I can't fiberglass cause I don't know what I am doing so I was going to build it out of MDF.
    Is it hard to fiberglass the spare tire well??
    Sep 2007
    ok... So i searched all over the net and found some good resources on fiberglassing the spare tire well. And I think I am going to attempt it so I can get a bigger box and the most out of my trunk space.
    My question still is, should I port the 15 or have a sealed box?? I know a ported box is much better for SQL and everything but will it be harder to port a fiberglass box then to seal it??
    Thanks again.
    Lakota's Avatar
    Lakota is offline Doesn't Know $hit
    Feb 2005
    Louisville, KY
    25
    6,232
    Port the L7 pleaz!
    Ben Hemp
    1992 GMC Sonoma Ext Cab NEW BUILD
    2008 MECA S1 KY State Champion, 151.0 dB
    2008 MECA S1 WorldChampion, 151.8 dB
    2010 MECA scores: 150.9 dB S2, 151.6 dB S3
    Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
    Stem's Avatar
    Oct 2005
    Kauai, HI
    24
    371
    yah dude, that L7 needs space, its a SQL sub, definitley port it
    Lakota's Avatar
    Feb 2005
    Louisville, KY
    25
    6,232
    Quote Originally Posted by Stem View Post
    I'd personally say spl.
    They don't sound that good, I don't care what other's say. I own one.
    Ben Hemp
    Jul 2007
    Futurama
    1,389
    Quote Originally Posted by Lakota View Post
    i agree my cvrs sound alot better than my l7
    Quote Originally Posted by bunkerking09 View Post
    i have a little weiner
  9. #9
    Sep 2007
    ok.. So a port on the L7. Got it.
    Thanks guys for your help. If I have any other questions, I will def let you all know.
    Greg
  10. #10
    M@nJo's Avatar
    M@nJo is offline CarAudio.com Elite
    Mar 2005
    bay area
    1,462
    sorry to threadjack superwhite06, but i thought id add a question while were on the topic.
    im considering the 15" l7 as a single driver getting 3.5cu space before port. im unsure whether to tune the box 38hz or lower. what would be a good spot to achieve maxium SPL but keep acceptable SQ for daily driving.
    refs: jalverson, hccafan, seth305, kevokrook77, bjfish11, jmanjr, allenzo, spy, erthshker, morgans432, Fuknmovin, evilsaint, Goindef154
  11. #11
    Sep 2007
    also how would I go about porting the box?? Just throw a port tube on the top of the box or port it with baffles??
  12. #12
    Lakota's Avatar
    Feb 2005
    Louisville, KY
    25
    6,232
    Quote Originally Posted by M@nJo View Post
    A bigger box tuned around 35hz. It's not easy to make a L7 sound good, imo.
    Ben Hemp
  13. #13
    jeremiah's Avatar
    jeremiah is offline edit me but not ****? ok?
    May 2006
    Canton Texas
    2,871
    I know I've hard some they sound bad.......but get loud
